Question about Kohler Home
Need a return faceplate for kohler jacuzzi - Kohler Home
Need to know where the reset button is on Kohler jacuzzi tub
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Aug 02, 2017 | Jacuzzi Home
Will epsom salts harm whirlpool
DO NOT use products with glycerine or oil in any Jacuzzi or whirlpool bath. It will harm the jets. Label oil or glycerine-containing gifts, "Not for Jacuzzi or whirlpool!"
May 03, 2012 | Kohler K-1110-AH-0 Purist whirlpool with...
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off...
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
May 19, 2011 | Kohler Archer Clearflo 1-1/2in Bath Drain...
What do I need to clean my sink with to keep the shine?
You can use Kohler cast iron kitchen sink cleaner, available on line, Jacuzzi recommends warm water, mild non-abrasive liquid soap for everyday cleaning and Barkeepers Friend or Zud for tougher stains. No Abrasives whatsoever. like Comet etc.
Mar 08, 2011 | Jacuzzi Kitchen Cast Iron Black Finish...
I have a kohler jacuzzi tub and many times over the past 5yrs the pump continously trips and the jacuzzi will not start. Any suggestions i have tried to reset the button unplug and plug it, an filled it...
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Feb 20, 2011 | Kohler Home
Need a flapper for the EZ 37/959 Jacuzzi toilet.
Lets see do you have a LOEWS, HOME DEPOT, or MENARD'S in your area? You can also go to the Jacuzzi website and pay out the yang for a flapper. Is there really a difference betwenn Jacuzzi and Kohler must be something special, sounds ritzy does it have jets around the bowl for comfort of ride or something, must be nice but to each his/her own. Good Luck!
Aug 13, 2010 | Jacuzzi Home
Kohler whirlpool control - missing wiring diagram - 1982
those parts made by unimax as you have found out are no longer made. solution is to put a new pump and control in.
Mar 22, 2010 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Home Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
