Question about Konica Office Equipment & Supplies
Biz hub 360
No power to control panel
    Habit-Forming:
    New Friend:
  • 106 Answers
Chech 1st the Contrast adjustment rotary before the power outlet.
Posted on Nov 03, 2014
2 Suggested Answers
  • 118 Answers
SOURCE: konica biz hub keeps powering off
i agree, this is a problem with some computers and servers and drivers, what is happening is that the post script driver is sending corupt files and copier cannot clear them so it has to reboot. try using the PCL driver
Posted on Nov 29, 2011
BIZ HUB C 360 AFTER 5 PRINT ERROR SHOW C 2558 OPEN FRONT DOOR & CLOSED , COPY QUALITY IS OK
Looks like Black Developing unit malfunctioning.
Replacement is the permanent solution..
Dec 17, 2016 | Konica Minolta Bizhub C360
I was changing the toner of Konica Minolta biz hub 163, and it shows a message that reads service call C0070. Please, what will I do to continue my work?
Sir/Mam,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Jul 13, 2016 | Konica Minolta Office Equipment & Supplies
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Xbox 360 Controller and USB Headset Conflict
Go to control panel, sound and audio, hardware, USB devices, and disable it. The computer thinks the XBox controller is an audio device and is giving it priority.
Aug 26, 2017 | Logitech 250 Headset
Dell precision 360 usb ports troubles, won't recognize any usb component or accesory, any usb mouse neither a usb keyboard, but they seem to be ok in the control panel.
Are you running XP or Vista?
If XP, go to control panel then to system then to advanced than to device manager. look for any YELLOW question marks and fix those.Especially in the USB Hub .
Mastersage
Feb 19, 2009 | Dell PRECISION 360 P4 HyperThreading 3200...
Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
Dec 25, 2008 | Microsoft Xbox 360 Controller
Xbox 360 Controller for Windows causes fuzzy sound
Found a solution! Came here to post it, since I could not find the solution ANYWHERE on the internet...
Using an Xbox 360 controller or any other Xbox 360 peripheral with 95% of USB sound cards or headsets will produce HORRIBLE sound input and output. It sounds like a robot has swallowed and spat back out the waveforms. Even if the 360 peripheral is removed any USB audio devices plugged in after the fact will still sound corrupted until a fresh reboot without the 360 peripheral plugged in.
I believe that the problem is somehow linked to the "generic root hub" driver, which hasn't been updated since 2001, thanks M$.
The solution (pick one of 3):
As long as the 360 peripheral is on it's own internal virtual root hub it will not interfere with other devices. You can force it to use another root hub by doing ONE of the following:
1) Fill up your usb ports with other devices till it shifts to using a secondary root hub, then plug in the 360 peripheral. This could take up to 10 USB things, depending on your motherboard and the maximum devices on each root hub.
2) Use an extra internal PCI-USB card for the 360 peripheral.
3) Use an extra external USB hub for the 360 peripheral.
NOTE: A reboot is usually required to clear up the driver's confusion.
Oct 24, 2007 | Microsoft MS Xbox 360 Common Controller...
13 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
