Question about Braun MULTIMAG SlideScan 4000
Calibrating problems no function
How do I access the functions above the keys?
Depending on the calculator, some are colour coded, so to get the function you want, you hit the associated colour function key and then the key with the function. Some calculators have two different colours, so each key has three functions assigned to it, one without a function key, one with colour key 1, and one with colour key 2.
Good luck,
Paul
Jan 23, 2016 | Office Equipment & Supplies
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
How to update older ti-84 plus
The function keys originally have twp functions: One function accessed by pressing a function key directly, the other by first pressing the 2nd key then the function key.
With the newer operating systems, there is a third function associated with the function keys F1.F2,F3 and F4, but not F5 nor F6. This third function is revealed after you press the ALPHA key.
Jul 25, 2012 | Texas Instruments TI-84 Plus Calculator
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
Need codes for ht3916 to chage remotes
Description=Durabrand Home Theater System (HT-3916)
Remote.name=URC-6131nwB00 PVR Remote 2K
Remote.signature=PVR0PVR0
DeviceType=Amp
DeviceIndex=3
SetupCode=1568
Protocol=00 5a
Protocol.name=NEC2
ProtocolParms=24 null null
FixedData=01 e7 e7
Function.0.name=Power
Function.0.hex=c7
Function.1.name=Mute
Function.1.hex=e7
Function.2.name=Source
Function.2.hex=d7
Function.3.name=Channels
Function.3.hex=67
Function.4.name=Reset
Function.4.hex=cf
Function.5.name=Front (-)
Function.5.hex=6f
Function.6.name=Front (+)
Function.6.hex=5f
Function.7.name=Center (-)
Function.7.hex=57
Function.8.name=Center (+)
Function.8.hex=df
Function.9.name=Rear (-)
Function.9.hex=47
Function.10.name=Rear (+)
Function.10.hex=ef
Function.11.name=Subwoofer (-)
Function.11.hex=77
Function.12.name=Subwoofer (+)
Function.12.hex=ff
Function.13.name=Master Volume Down
Function.13.hex=4f
Function.14.name=Master Volume Up
Function.14.hex=f7
Button.8=Mute'null'null
Button.3=Power'null'null
Jul 23, 2011 | Durabrand HT-3915 System
All function that can be used in excel
Use this link to download all excel Dicttionary function
http://www.xlfdic.com/
Thanks for choosing Fixya.........
Sandeep
Mar 18, 2011 | Excel Function Dictionary
What is the function of 1st,2nd,3rd,4th,5th gear?
the function of the gears are to transfer and convert energy created by the engine into momentum
Feb 12, 2010 | 2003 Toyota Corolla
Multimedia keyboard on function keys. Functions work with a key "Function" How to change "Multimedia keys first" on "Function keys first" ???
You can change the settings by going to BIOS. To go to BIOS, restart the system and as soon as you restart, start tapping the <F2> key located on the keyboard. This will take you to BIOS.
You can use the Function Key Behavior setting in the System Setup (BIOS) utility to configure the media control keys. The options in the Function Key Behaviour setting are:
Multimedia Key First - This is the default option. Press any multimedia key directly. For function key, press <Fn> + the required function key.
Function Key First - Press any function key directly. For multimedia key, press <Fn> + the required multimedia key.
Nov 01, 2009 | Dell Inspiron 1545 Notebook
Graphing inverse equations
In parametric mode you are not drawing one function, but two functions X1(T) and Y1(T). If you use the DrawInv( command either on X1(T) or Y1(T) you get a syntax error.
However if you are drawing functions in Funct mode you can draw the inverse of the function that has been graphed.
Here is how you do it.
[2nd][Draw][8: DrawInv] [ENTER]
The command appears on the home screen, and you need to tell it the function it will act on. To do so press
[VARS] --> Y-Vars [1:Function]
and select the function you want, say Y1, if Y1 has already been defined.
DrawInv Y1 [ENTER]
Both Y1 and its inverse will be drawn.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-84 Plus Silver...
Plz answer, thanks!!
Click the Office Button in the upper left corner. Click "Save As"
Click "Tools" and select "General Options"
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
There you can set a password to open the file or a password to modify the file.
function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); } function go(url) { window.open(url, "_self"); } function OpenInNewWindow(url) { go(url); }
Jun 25, 2008 | Microsoft Office Professional 2007 Full...
Open Questions:
See all Braun MULTIMAG SlideScan 4000 Questions
Braun MULTIMAG SlideScan 4000 Logo
19 people viewed this question
Top Braun Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a Braun Office Equipment and Supply Expert? Answer questions, earn points and help others
