A
Anonymous Posted on Feb 15, 2014
How do I disable the demo mode for a philips DCM580
1 Related Answer
Anonymous
  • 8546 Answers
  • Posted on Aug 13, 2011
SOURCE: how to disable demo mode for DCM580/93?
You could web search "Philips DCM580 demo" to find it. Look at the FAQ's.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=sa&ctn=DCM580/12
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
tip
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
Demo mode will not shut off in lower left corner
Please follow the below mentioned procedure to disable Demo Mode in Acer Iconia Tablets.
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
Regards
How can get out from Iconia A1 810 DEMO Mode
Demo mode on ipad 3
Disabling store demo mode If you consider installing the configuration file included below make sure you understand how to disable this mode first.
Mobile configuration files are used to configure phones in enterprises. Apple provides an app called the iPhone Configuration Utility (IPCU) to install and remove configurations. To disable store demo mode:
  • Use IPCU to remove the configuration from the phone
  • Reboot your device
2helpful
I can't get my Philips Aria mp3 player out of demo mode.
Use next information to page in the players menus:
Go to
Settings >
Display settings >
Screensaver >
Demo Mode
Select Demo Mode and turn off the demo mode.
17helpful
2answers
How do i turn offthe demo mode on a philips
On any appliance that has demo mode the solution is usually to hold down the stop button for like 3 seconds.
7helpful
CANCELLING the demo mode
Once the demo has started, press the STOP button on the front panel for 3 seconds. Demo will stop and the unit will enter standby.
You can download the user manual here:
https://www.p4c.philips.com/files/f/fw-r7_22/fw-r7_22_dfu_eng.pdf
2helpful
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
