Question about Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset
Parrot hands free stuck on 'goodbye' - Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset
SOURCE: passcode for hands free parrot bluetooth device
on the device
go to settings - pair with phone... - other phone
and the pin code will be dispayed on the screen
Posted on Apr 08, 2009
For the Parrot Minikit- that attaches to the visor. The default is 1234
Posted on May 28, 2009
dancandoit
  • 436 Answers
SOURCE: my nokia n95 will connect to my parrot hands free
Object Push: To send one contact:
* From your phone go to MENU / CONTACTS
* Select the desired contact to send and go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The phone will start searching for available devices
* Select Parrot Product from the list of available devices
* The contact will be transferred
To send several contacts:
* Select the desired contacts to send with OPTIONS / MARK/UNMARK / MARK
* After the desired contacts are selected go to OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH
* The contacts will be transferred
Posted on Oct 10, 2009
  • 95 Answers
SOURCE: fitting hands free car kit Parrot CK3000 Evolution
Just make a look:
http://www.parrot.com/uk/support/onlinehelpguides/parrotck3000evolution
Posted on Mar 26, 2010
  • 3 Answers
SOURCE: Blue parrot b250xt when making a call cant hear it
Seems like you have an issue that is very common. I had the same issue and phoned tech support (1 800 742 8588). The solution is to reset the headset. It is not printed in the manual 1 switch phone on and pair with headset. 2 when paired (blue light flashing) put the charger on the headset for exactly 10 seconds. 3 remove the charger. 4 the lights should be starting to alternating between red and blue. this means it is resetting. 5 as soon as the light quits to alternate, the headset is reset, and the problem should be solved.
This also fixes the Windows 6.1 audio problem.
Posted on Aug 09, 2010
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot bluetooth ck3100 - my parrot is not working and is displaying goodbye on the screen. Any ideas would be appreciated
power supply problem or any power issue must be the problem.
(battery).
if all are ok cct board problem.
regards.
nuwan
Jul 16, 2014 | Parrot Ck3000 Evo/pf180035ac...
My Parrot display says "Goodbye" and I cannot pair
This kit has frozen and will need to be reset by unplugging the main blue box for a few minutes, this should rectify the fault. If this does not work you will have to upgrade the software on the Parrot.
Sep 24, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Hi Guys had a parrot with LCD display for a few years now when I start the engine it does not boot up, normally if you have the phone with you it will prompt you to connect if you dont have the phone with...
The software has crashed. You can try pulling the fuse for the parrot and it may boot back up but i would do a software update if you have had it a few years. Make sure the kit says 'goodbye' when powering off, if not then it is wired wrong. Parrot web site has a list of certified installers.
Feb 21, 2011 | Parrot Hands-Free Car Kit with LCD Display...
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
When engine turned off Parrot unit remains in GOODBYE mode and fully lit
it has has a software crash, you will need to have the blue junction box unplugged to reset it, this may also not work and you may need new software putting into the parrot, if in doubt go to parrot.com and find an accredited engineer in your area.
Dan
Feb 23, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
When switched ignition off looses memory. parrot 3100.
The perm and ignition live are the wrong way round, change the wires around at the fuses, it should go red to red and orange to orange at the moment, change it to red to orange and orange to red, Should then say goodbye on the screen when you turn off the ignition.
Nov 22, 2009 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Wont turn off....says Goodbye on the screen
you will need to remove power from the parrot main control box hidden behind the dash, it may then require new software.
Nov 21, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Reads "Goodbye" and I cannot turn it back on. Have tried to sync from phone numerous times. Its not that.
If the display is stuck on goodbye then you will need to reset the brain box by disconnecting for a couple of minutes.
Nov 16, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Hello I have a Parrot CK3100 bluetooth hands free car kit, which stopped working after the cars battery went flat. The unit just has 'no signal' now and that's it! Can you help me please
You will need to find the main blue box and unplug for 5 mins. also check live and igition is wired correct. parrot should say disconnected then goodbye when switched off.
Sep 29, 2009 | Car Audio & Video
Parrot MINIKIT Bluetooth Hands-Free Kit Wireless Headset Logo
15 people viewed this question
Top Parrot Radio Communications Experts
Hjalmer Lamminen
Hjalmer Lamminen
Bill Boyd
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
