Question about Candy Washing Machines
Candy 1682 error e04 - Candy Washing Machines
Candy error e04
Multiple instances of anti-flood contacts in pressure switch being made
·Check for overfoaming evidence - can trip pressure switch
·Check wiring to level sensor
·Check pressure switch is not defective
Water inlet valve locked open
May 07, 2014 | Candy AQ130 Front Load Washer
Code
Apr 14, 2014 | Candy EVOW6853D
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Error code 1682
code 1682 ignition 1 voltage low input condition.possible causes ignition 1 voltage circuit is open high resistance or it is shorted to ground. ignition 1 power supply is open test ETC1 FUSE in fuse block.PCM has failed.
Jun 16, 2013 | 2008 GMC Acadia
Treadmill error E04
"E04": Incline motor wrong, check if the VR of the incline motor connects well or replug it. The
mark of the DC motor and control board should be matched connected. Sometimes you alsoneed to check the wires of the motor and restart the whole treadmill again
Jan 10, 2013 | Exercise & Fitness
My candy go1682 makes a very loud banging noise on spin,it almost sounds like a plane taking off. julie
Suspension/Damping stut has failed , you need a new one pronto
Worst case is that the inner drum has come loose from the mounting on the back
Oct 02, 2009 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
15 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
