Question about Bose Wave Radio II
Bose wave radio turns off
The unit turns off on its own. It is as if the power button on the remote is pressed. We can press the remote's power button and it turns back on with no problem. It happens when there is not other IR remote activity in the room. It happens at seemingly random intervals (might play for 20 min or 4 hours). It is not correlated to the what we are playing or any CD problems.
simplemitch
  • 752 Answers
SOURCE: cd play problem
Laser is dead. Call bose and they will service it for you for about $75.
Posted on Sep 22, 2007
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: BOSe Wave Radio - Disk "not readable"
I had the same problem with the disk unreadable error and took my unit to a authorized repair dealer about 100 miles from where I live to have it fixed. It ended up costing me about $300 to have the CD unit totally replaced which is almost as much as I paid for the unit in the first place. I am like a lot of you that used the CD very little although the unit was about 3 years old. I think Bose has a problem and would like us to think it is very rare. I bought a Lifestyle surround system about 14 years ago that has a CD and have never had a problem with it so needless to say I am very disappointed in the Wave II Radio/CD system. I am fairly certain the problem will occur again, but only time will tell.
Posted on Sep 02, 2008
Why bose wave radio touch pad does not work ?
There's a setting to turn the touchpad on or off. Yours has probably been turned off. Here's how to turn it on.
1. Press and hold Alarm Setup (Menu) on your remote until -SETUP MENU- appears in the display.
2. Press Tune/MP3 until TOUCH PAD- is displayed (8 presses)
3. Press Time- or Time+ to select OFF or ON
4. Press Alarm Setup (Menu) to exit the menu, or simply wait 10 seconds.
You're done!
Jul 22, 2014 | Bose Wave Radio
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Sep 08, 2011 | Bose Wave Radio
How do you change time for daylight savings time?
On the Bose Wave Music System clock radio remote there is a + and - button labeled "time." This is how you set the time. Hold either the + button to move the time forward or the - button to set the time backwards. You don't need to push any buttons before you press the + or -. After you have set the time you can press the "alarm time" button to lock in your changed time.
Read more: http://wiki.answers.com/Q/How_do_you_change_the_time_on_a_Bose_Wave_Music_System_clock_radio#ixzz1GUIzfXCp
Mar 13, 2011 | Bose Wave Radio
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
Jan 27, 2011 | Bose Audio Players & Recorders
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
My bose wave radio II remote is not working. I
It will work without the remote, but can ve very unconfortable. If you have a webcam or digital camera or cell phone with camera, then point it to the small lamp in front of the remote and press any button. If the light blinks or keeps on, then the problem may be on the radio receptor. If light is dark, then take it to an electronics store an ask for an INFRARED LED DIODE replacement. This should work well.
Nov 20, 2009 | Bose 35503 Remote Control
Apr 09, 2008 | Bose Wave Radio
Bose Wave radio
Use the tune arrow buttons on the remote - left arrow tunes down; right arrow tunes up.
Once you have the right frequency for the station you want to preset, press and hold the number button that you want to store it under for around 5 seconds
Jan 10, 2008 | Bose Wave Radio
Power off and on again and then no sound present
i assume pressing the source button on the remote control is how you normally turn it on again, (ie video FM CD etc)
it might be that moving the unit to the cabinite the battery power in the remote ( its not infra red its radio wave thay are not picked up by the fm antenna ) is insufficient to wake it up again,
change the batteries in the remote or try to see if there is some weird reason the cabinet is preventing these remote control radio waves from being recieved by the head unit, try opening the door and bring the remote within a few inches of the head unit and see if it turns on when you pres the cd button.
see how you go from there mate
Nov 30, 2007 | Bose Lifestyle 12 System
Bose Wave Radio II Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
