Question about Coffee Makers & Espresso Machines
Pushing the cappuccino button but no milk is coming out
Lattissima - after pushing the cappuccino button, no milk is coming out, just just vapor. then the water with the coffee coming out
SOURCE: Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
SOURCE: bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Posted on Jun 04, 2009
  • 1089 Answers
SOURCE: Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Posted on Jul 09, 2009
  • 3 Answers
SOURCE: Russell Hobbs coffee maker
I found someone in NZ who sells a complete set.
http://www.trademe.co.nz/Home-living/Kitchen/Tea-coffee-making/Coffee-machines/auction-236701780.htm
Posted on Oct 17, 2009
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
Milk does not come out
remove the milk hose and the dispenser. grab the dial that lets you change between milking a cappuccino and a flat white, pul is straight out of the removed section. You will find slots in the shaft that are choked with milk solids. This happens when CAPPY RINSE is ignored.
Nov 12, 2013 | Jura Impressa X9 Espresso Machine
Which kind of plant-based milk is best to make cappuccino?
One can use many types of plant based milk for making cappuccino. It can be soy milk, almond milk, coconut milk, chia milk, hemp milk, rice milk, oatmeal milk, hazelnut milk or any other.
According to my taste, I always use almond milk to make a cappuccino as it provide a great taste and flavour to the cappuccino.
Jul 03, 2013 | Wine & Spirits
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
Sep 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
I have a expresso cappuccino maker model CC30. It is a Maxim-it is white with a red push button on top.. Does anyone have instructions for this..i don't and need some.. Thank you-gerry
nothing to know, put water in it..plug in..no steam should be coming out, until you push the red lever..put in your milk or cream
stick probe down at bottom of cup. steam until mixture gets thick
Jul 13, 2010 | Salton CC30 Plus Coffee Maker
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
I cannot get my Nespresso Lattissima to clean out milk when clean button is pressed, nothing happens. Can you help me?
Have to pull out the entire container and push it back into the unit so it fully connects with the machine. Then try again.
Dec 04, 2009 | Nespresso Lattissima 660.R
Hi
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
How to work Spidem Cappuccino Instantly Espresso Machine
the coffee portion of the knob only allows the instant coffee to be added to the mixing process, then when the knob is turned to the milk selection, the milk is frothed and the instant coffee is added and dispensed into a container under the dispenser area on the front of the machine......Hope this helps.
Aug 16, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
10 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
