Vacuums Logo
A
Anonymous Posted on Feb 15, 2014
How to take cover of to renew belt vax power 2 (scent of summer 1800watts
1 Related Answer
small6363
  • 18429 Answers
  • Posted on Feb 21, 2013
SOURCE: Could someone please advise how to remove the cover on a Vax Power Pet 2. I'm trying to change the belt, have removed the screws from the sole plate but the cover seems to be held in place by the
go here > http://support.vax.co.uk/power-2-upright and download the manual with full instructions
There is a black residue coming from the motor in the scent chamber. what could cause that/
Amanda:
The black residue is probably coming from the drive belt that goes from the motor to the beater bar. Lay the machine on it's back, and remove the foot plate (or cover plate for the belt) and check the belt for wear.
1helpful
I have a vax mach air u91-ma-b where's the drive
click on the link below and you can dowload the manual witch will give you instructions how to change the belt
Mar 20, 2013 • Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
25helpful
4answers
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
1helpful
How do i change the belt on my Vax V-015 06w46
Remove the two screws from the top cover, remove top to expose belt & replace. Replace top cover.
4helpful
HOw to change the Belt on a Vax VX1 Model
There is a brush reset button on the handle. Check to see if this has been pushed in. Also check to see that the brush slider has also been switched on. Usually belts are protected on this model but you should be able to remove the bottom sole plate where the base of the vacuum is (and beater bar). If the belt cover can't be removed then it has to be repaired professionally.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
