Question about 4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck /
Overfilled transmission in 700r4 transmission
Overfill problems
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
Overfilling can cause foaming which results in poor engagement and shifting. Harbor Freight has a nice little suction pump for $6 that will remove excess fluid without pulling the pan. http://www.harborfreight.com/multi-use-transfer-pump-66418.html
Good luck.
Posted on Nov 26, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Can a transmission malfunction if overfilled with transmission fluid?
How Does Overfilling Cause Problems? If you overfill the transmission, you will find that the fluid may foam, and that can lead to erratic gear shifting. Other problems can include transmission damage and oil starvation.
Jan 14, 2016 | 2003 Nissan Frontier Crew Cab
Transmission fluid showing over fill. What causes this?
overfilling or a faulty indicator? overfilling does not present a problem as far as I know....underfilling does though.. I am referring to an electronic notifier here.
You might want to manually check that every thing is as it should be before checking for component faults.
Aug 01, 2015 | Cars & Trucks
Where do i put the gearbox oil on the chev lumina ss 2008
If it's a manual transmission then there should be a check plug on the side of the transmission. It should have a 4 sided plug you can remove with eather a 15 or 16 mm open-end wrench or an adjustable (crescent) wrench. Don't overfill, but keep it within 1 inch of the bottom of the check plug hole. Carefully use an allen wrench to check. If the vehicle has an automatic transmission and it has a transmission dipstick, then you can fill it through the dipstick tube but again do not overfill. Drive after filling and with the oil warm ensure the oil level is within the warm/hot cross hatches on the dipstick. Do not overfill. If there is no transmission dipstick on the automatic, then take it to your dealership to fill.
Dec 18, 2012 | Chrysler Town and Country Cars & Trucks
I have a 1998 626 Mazda transmission fluid overfilled
It could, because as the fluid get warm it expands. As it expands it might not flow thru the system as it was designed too. You might check your motor mounts also. I had a mini van that i thought the transmission was shot. It would **** and bounce. After getting under it I found 2 of its motor mounts were broke. When I fixed the mounts the jerking and bouncing went away.
Jul 14, 2012 | 1998 Mazda 626
Need help, I cant seem to locate the dip stick & the topping section for the transmission
Your transmission is not equipped with a dipstick. (At least, there is a good reason you can't find it, Huh? You really aren't blind after all...LOL!)
To check your transmission fluid level, follow this procedure:
1. Ensure that the vehicle is level, with engine running at idle and parking brake applied. The fluid temperature should be cold. (after sitting for several hours) Move the selector level through all the gear positions and end in PARK.
2. Let the engine idle for three minutes and open the OVERFILL screw on the bottom of the transmission pan. The transmission is filled through the OVERFILL screw hole. The fluid will seek the correct level and will flow out of the OVERFILL screw hole. (See picture)
P.S. take a drain pan with you under the vehicle...you will need it.
May 15, 2011 | 1998 Isuzu Rodeo
Where is the transmission dip stick
On 1996 and later models, the transmission uses an overfill screw instead od a dipstick. On the transmission pan there are 2 screws, one is the drain plag and sits lowest and to the rear, the overfill screw is to the rear on the passenger side, this is where you fill with fluid until it just starts to run out of the opening.
Feb 06, 2011 | 2002 Isuzu Rodeo
Where do I add transmission fluid
pour the fluid in the tube where the transmission dipstick is located, only add about a pint at a time as you dont want to overfill because the is no easy way to drain off excess and overfilling can be worse than running it a little low
Jan 14, 2011 | 1997 Buick Riviera
WHAT DOES THE TRANSMISSION CAP HAVE ON IT?
Transmission cap? To add fluid? If that is what you mean, there is no cap and filler tube. You use an automatic transmission fluid funnel (long and thin) and refill the fluid through the transmission's dipstick tube. Pour the fluid in slowly and check level often to avoid overfilling. Use the correct ATF specified by GM and DO NOT overfill your transmission. I hope this helps.
Jan 30, 2010 | 2004 Chevrolet Cavalier
Need to add tranny fluid to '99 Rodeo, but where??
CAUTION: DO NOT OVERFILL.
Overfilling will cause foaming, loss of fluid, abnormal shifting and possible damage to the transmission.
1. Park the vehicle on level ground and apply the parking brake firmly.
2. Check fluid level with engine running at idle.
NOTE: Be sure that transmission fluid temperature is below 30degrees C (86degreesF).
3. Move the selector lever through all gear ranges.
4. Move the selector lever to “Park”.
5. Let engine idle for 3 minutes and open the overfill screw (1).
6. Add released transmission fluid until it flows out over the overfill screw opening.
7. Let engine idle until a fluid temperature between 32C (90F) and 57C (135F) is reached, then close the overfill screw (1).
Torque: 38 Nm (3.9 kg·m/28 lb ft)
NOTE: To prevent fluid leaks, the overfill screw and oil drain screws gasket must be replaced each time these screws are removed.
CAUTION: Do not open overfill screw with engine stopped.
CAUTION: DO NOT CHECK FLUID LEVEL UNDER THESE CONDITIONS:
 Immediately after driving at sustained highway speeds.
 In heavy city traffic during hot weather.
 If vehicle is towing a trailer.
If the vehicle has been operated under these conditions, shut the engine off and allow the vehicle to “cool” for thirty (30) minutes. After the cool down period, restart the vehicle and continue from step 2 above.
Aug 07, 2009 | 1990 Isuzu Trooper
4L60E/700R4 Transmission Pan 82-97 Chevy & GMC Truck / Logo
162 people viewed this question
Top Mag Hytec Vehicle Parts & Accessories Experts
Robert Rankin
ray gallant
Tom
Are you a Mag Hytec Vehicle Part and Accessory Expert? Answer questions, earn points and help others
