Question about Dyson DC35 Handheld Vacuum
Power going on and off - Dyson DC35 Handheld Vacuum
Why is my power head not working
You either have a broken power cable going to the head or your canister isn't supplying power to the head, or the motor for the head it bad.
Dec 13, 2015 | Shark Professional Canister Vac - EP754 -...
Brown wire came off where does it go. electrolux guardian power nozzel
send me picture of the wires and connection location, then I'll be able to help
Jun 13, 2012 | Electrolux Guardian Bagged Canister Vacuum
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
This is the first time I'm using my Mr Coffee Frappe maker and after plugging in the machine and pushing the power button, nothing happens. Should the red light come on right away?
yes you should get some kind of power indicated that power is on the machine i would first check the circuit breaker and then assure that you have power coming out of the outlet after which you could then use a multimeter to folow where you do have power going to sometimes it could also be a bad switch on the unit itself but first assure where you do have power going to and any further questions message me back Thanks Rick
May 19, 2011 | Vacuums
Replaced Oreck power switch. 2 black leads and 1 white lead for switch. Posts marked 1, 2, and 3. 2 black wires to switch powers on. Connect white wire and breaker trips. Where does the white wire go?
Both black go to the switch. Power in - black to switch / white to white from motor.
From motor - black to switch / white to white from power cord
The black wire from the power hooks to the off end of the switch and the black wire from the motor hooks to the on end. Third post is not used. The two white wires are connected to each other with a small twist on wire nut.
Nov 01, 2010 | Vacuums
When I disconnect the power nozzle on my central vac I have no power for the accessory items
If there's power to the power nozzle, there's power going to the powered accessories, as well. The problem must be due to a defective/broken "item". It could be a loose wire, a switch, or the accessory motor. It needs to be replaced, or taken in to an authorized shop for repair.
Aug 14, 2010 | Electrolux Central Vacuum
Power cord is loose, power cuts off
If its the Auto wind cord then fault could bre internal contacts, not easy to get into suggest best to go to service centre.....
Oct 10, 2009 | Miele s558 Silver Moon Vacuum
GE canister vac 106766 power not going to brush head
Try checking the hose connector cord (short cord from bezel outlet to hose). Also, check the prongs on on extension wands.
May 19, 2009 | GE 106766 Bagged Canister Vacuum
Doesn't go on
it could be the switch they do fail. i would test the power do you or someone you know how to use a multimeter if so test the wires for power in the on and off position if it has power to both sides of the switch than it is for sure good if not its bad, if its good test and see if you have power to the motor if it does then the motor is bad if not test power to all items along the wire until you find the place where the power stops and that will be your bad part.
Nov 29, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson DC35 Handheld Vacuum Logo
21 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
