Question about Prince of Persia: Warrior Within for Windows
Prince of percia wrriors within exe has stop working
Prince of persia two throns not working my pc just show unknown amd proccessor? what should i do to play this game ?
hai, you have to do:
first run the program "princeofpersia.exe" from installed folder. this will detect the supported hardware and o.s.
second: don't quit the program after detecting.
third: run the program pop3.exe from your installed folder. it will magically run the game .
Don't quit the first program........................enjoy..THANKS
Feb 08, 2013 | Ubi Soft Entertainment Prince of Persia:...
HOW TO USE TRAINER IN PRINCE OF PERSIA WORRIER WITHIN
First play the trainer of prince of persia then play game.Press hot keys of trainer.Then work your trainer.
  • eg of hot keys is F2 F3 F4 F5
Mar 22, 2012 | Ubi Soft Prince of Persia: Warrior Within...
I downloaded prince of persia warrior within and want to play it, but when i clicked on princeofpersia warrior within.exe, it showed that it is not a valid win32 application.
Make sure ur using windows xp
and hardware minimum requirement
then also same problam it mean ur exe is currrept try to replace ur exe file
Sep 22, 2011 | Ubi Soft Prince of Persia: Warrior Within...
I have download prince of percia sands of time setup.when i try to install it,the msg appear that ;you can not play this game,you have to live in USA, PLZZZZZZZZZZZZZ help me
Close all your internet connections and then try running the game......IF the problem still persists find if you can get a crack for the game,which is easily available on net.
Thank you
Jun 24, 2011 | Ubi Soft Prince Of Persia: The Sands Of...
Need ubi info.-username and password to run setup
i have downoload prince of percia & when i install it need user name & passwor will u plzzzz help me
Feb 16, 2011 | Ubi Soft Prince Of Persia: The Sands Of...
Want game key
The Install Key for Prince of Persia: The Two Thrones is:
BZ7A9-X488N-725MY-E9FND-TLPDZ
Please note, this key code is only used for the installation
Aug 25, 2009 | Ubi Soft Entertainment Prince of Persia:...
Prince of Persia - The Two Thrones - Doesn't Start I am running:- Core2Duo, Windows XP, SP2, NVidia Gforce 7600GT, Dual Monitor, dxdiag 9.0c When I run pop, it says checking disk, then goes to direct draw...
make sure u run demon tools before running the game,,,
ang also update the starforce protection software to make the game work in any os...
the link is
http://www.star-force.com/support/drivers
Apr 26, 2009 | Ubi Soft Entertainment Prince of Persia:...
Prince of Persia: Warrior Within for Windows Logo
14 people viewed this question
Top Prince Video Game Consoles & Games Experts
Andrew Taylor
Andrew Taylor
 steve
steve
Are you a Prince Video Game Console and Game Expert? Answer questions, earn points and help others
