Question about Roper REX4634KQ Electric Dryer
Heats up but turns off
No matter where I start it, it heats up but the dial doesn't move and it turns off after 15 minutes.
    Scholar:
  • 101 Answers
Most likely you have a control board problem. All those issuse point to the only thing that effects all those parts/functions of the dryer. This is about a $100 part. Call Sears parts and get a quote or go to http://www.searspartsdirect.com. Labor to replace will be in the $80-120 price range unless you bring it to a repair shop which could be cheaper.
Posted on Feb 16, 2014
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
My 2004 silverado crewcab battery went dead and was replaced. The Air conditioning system now only blows through the defrost vents and the dial to change the airflow does not work. Can this be reset?
Turn the key on and make sure the blower motor is working. It doesn't matter what speed. Turn the key off. Pull the hvac1 fuse out of the under hood fuse box. Wait five minutes. Reinstall the fuse. Turn the key on, do not start the engine or touch the heater controls. You should hear the heat swiping through the different modes. After a couple of minutes it should stop. Turn the key off then start the vehicle. It may take several tries but eventually it should recalibrate.
Sep 17, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
The dryer is running, but it has no heat. When you place the dial on 30 minutes it doesn't move at all, it just stays on the number. It does run and move the drum around, but no heat at all.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 05, 2011 | Dryers
Having a hard time "setting" it to turn on/off
Question is not clear: Add a comment for more information.
1) Did timer work before and stop working?
If timer stopped working, then buy another one for $15.
2) Is this a new timer?
Is the wiring correct?
Does the on-off switch turn load on and off?
GE 15068 is countdown timer.
Following link has a photo showing example timer:
http://ecx.images-amazon.com/images/I/311ev7wNxkL._SL500_AA300_.jpg
To operate countdown functions, move slide switch to Timer.
Rotate dial to one of the numbers shown on dial, for example 15.
Timer will turn on Load.
Timer begins counting down for 15 minutes.
When countdown expires, load turns off.
Jun 17, 2011 | Jasco Products 15068 White 30 Minute Wall...
I have a Kenneth Cole KC1683 watch. I don't understand what the dial at the top left does. There are 3 dials. The main one has the hour and minute hands. There is another small one for the seconds....
It is the dual time zone dial. Set it for another timezone, like London or whatever you're interested in, a timezone your friend is in so you don't call them at 3 in the morning.
May 22, 2011 | Kenneth Cole Watches
It will not turn on it says it locked how do i get this off of the screen and get it to turn on quiet flow is the nameof it
Crystal, first turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12-15 minutes before plugging the unit back in. After you plug it in, turn the Master ON/OFF Switch to ON and set the controls as you wish. Hopefully, during that 12 - 15 minute timeout, the unit reset itself and should now work normally.
If that doesn't solve the problem, you can call Hunter Technical Support. In the US dial 888-830-1326.
In Canada dial 866-268-1936
Apr 15, 2011 | Hunter Air Purifiers
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Heat/Cool gauge fluctuates inconsistently
You might check the coolant level after the engine cools,if it's low add 50/50 mixture of coolant and water. Keep an eye on the level to see if it happens again. You might have a small leak in the system. Good luck
Jan 18, 2010 | 1998 Volvo S90
Gas dryer not maintaining heat. The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob)...
The problem is with the 2 little circular black coils next to the ignitor. They need to energize before the gas valve can open. They tend to get weak over time. I am 100% sure this is your problem. Good luck :)
Jul 14, 2009 | Washing Machines
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Roper REX4634KQ Electric Dryer Logo
32 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
