Kd061aa pin out - Computers & Internet
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
07 chevy suburnan wiring diagram color
Item12 VoltsSecond 12 VoltsStarterSecond StarterIgnitionSecond IgnitionThird IgnitionAccessorySecond AccessoryThird AccessoryKeysenseData BusCan Bus HighCan Bus LowCan Bus SwPower LockPower UnlockLock MotorDriver Unlock MotorPassenger Unlock MotorParking Lights (-)Parking Lights (+)HazardsTurn Signal (Left)Turn Signal (Right)HeadlightAutoLightsReverse LightLeft Front Door TriggerRight Front Door TriggerLeft Rear Door TriggerRight Rear Door TriggerDome SupervisionTrunk/Hatch PinRear Glass PinHood PinTrunk/Hatch ReleaseTrunk Release MotorFuel Door ReleasePower Sliding Door (Left)Power Sliding Door (Right)Factory Alarm ArmFactory Alarm DisarmDisarm No UnlockTrunk Alarm ShuntTachometerWait to StartNeutral SafetyClutch PedalFuel PumpRear DefrosterMirror DefrosterLeft Front Heated SeatRight Front Heated SeatSpeed SenseBrake WireParking BrakeHorn TriggerWipersLeft Front Window (Up/Down)Right Front Window (Up/Down)Left Rear Window (Up/Down)Right Rear Window (Up/Down)Sun Roof (Open/Close)Sun Roof (Limit/Close)Memory Seat 1Memory Seat 2Memory Seat 3Radio 12VRadio GroundRadio IgnitionRadio IlluminationFactory Amp Turn-onPower AntennaLeft Front Speaker (+/-)Right Front Speaker (+/-)Left Rear Speaker (+/-)Right Rear Speaker (+/-)Center Channel (+/-)Subwoofer (+/-)Aux. Audio Input Left (+/-)Aux. Audio Input Right (+/-)RSE Video (+/-)RSE Audio Left (+/-)RSE Audio Right (+/-)Satellite Radio 12 VoltsSatellite Radio GroundSatellite Radio IgnitionSatellite Radio AntennaSatellite Audio Left (+/-)Satellite Audio Right (+/-)HeadunitLeft Front SpeakerLeft Front TweeterRight Front SpeakerRight Front TweeterLeft Rear SpeakerLeft Rear TweeterRight Rear SpeakerRight Rear TweeterCenter ChannelSubwooferLeft Front HeadrestRight Front HeadrestLeft Rear HeadrestRight Rear HeadrestSatellite Radio Tunerspacer.gifspacer.gifWire Colorred/black (60A), red/black (60A)red/white (x4) (15A each)purple (for starter kill only)pink/black (resistor code), white (5V reference)pinkN/AN/Abrown or yellowsame as second starterN/Asame as second starterdk. green (low speed GMLAN)tan/black (high speed GMLAN)tan (high speed GMLAN)dk. green (low speed GMLAN)use Directed interface modulesee power lockgraypurpletanlt. bluebrown (L), brown (R)whitelt. blue/white (F); yellow or yellow/black (R)dk. blue/white (F); dk. green or dk. green/wht (R)whitedk. green (ground to turn off autolights)dk. bluegray/black (ajar), tan (open)black/white or tan/whitelt. blue/blacklt. green/blackgraypink/blacksame as trunk/hatch pinpink/blackgray (liftgate), pink (liftglass) (rear handle sw)lt. blue (liftgate)N/AN/AN/Aarms on lock with door openlt. green (driver door key cylinder)Passkey and ignitionN/ANOT pinkN/AN/AN/Adk. green/whitepurpleorange or black (L), orange or black (R)dk. blue (back and cushion)dk. blue (back and cushion)dk. green/white (some models only)lt. blue/white (functions with ignition on only)lt. bluetangraydk. blue - browndk. blue - browndk. blue - browndk. blue - brownbrown - org or lt. blu (function with ign on only)N/Aorangesame as memory seat 1N/Ared/whiteblack(low speed GMLAN)yellow (dimmer)same as power antenna (some models only)whitetan - gray or tan - dk. greenlt. green - dk. green or lt. green/white - org/blkbrown - yellow or brown/white - browndk. blue - lt. blue or dk. blue - tandk. blue - orange (with surround)white - pink (with surround)yellow - (bare wire)white - (bare wire)dk. green - white/blacklt. blue - purplewhite - purplered/whiteblack(low speed GMLAN)(coaxial cable)brown/white - tan/whitedk. green/white - graydouble DIN6.56.55.255.25spacer.gifspacer.gifPolarity++++9.6K ohms+++6.3K ohmsdatadatadatadata5 wire5 wire5 wire-+-++--+----+---+-ac+reverse+ latched--ac+--+AAAA-+2.26Kohms+4.26Kohms+-+++,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+,-+-+,-+,-spacer.gifspacer.gifWire Locationdash fuse box, black 40 pin plug (X1), pins F1 and E3BCM, black plug, pins 1, 2, 3, and 4starter or underhood fuse box, blk 50 pin plug (X2), pin F1 or F5ignition switch or BCM, lt. green plug, pins 2 and 4ignition switch or BCM, lt. green plug, pin 14ignition switch or BCM, lt. green plug, pin 21PASS-Key III+ Module, black 5 pin plug, pin 4data link connector, black 16 pin plug, pin 6data link connector, black 16 pin plug, pin 14data link conn, black 16 pin plug, pin 1 or BCM, lt. blue plug, pin 10driver kick or dash fuse box, black 14 pin plug (X3), pin B4driver window switch, brown 16 pin plug, pin 8driver kick or dash fuse box, black 14 pin plug (X3), pin B1headlight switch or BCM, white plug, pin 8underhood fuse box, black 30 pin plug (X3), pins A7 and F7hazard switch or BCM, lt. green plug, pin 19BCM, brown plug, pins 4 and 1BCM, black plug, pin 5; brown plug, pin 2headlight switch or BCM, white plug, pin 12headlight switch or BCM, white plug, pin 17BCM, white plug, pin 22driver window switch, brown 16 pin plug, pins 13 and 11passenger window switch, brown 16 pin plug, pin 13BCM, pink plug, pin 15BCM, pink plug, pin 14BCM, white plug, pin 5BCM, pink plug, pin 12hood switch or BCM, black plug, pin 17BCM, pink plug, pins 13 and 24passenger kick, harness to reardriver window switch, brown 16 pin plug, pin 4any fuel injectorECM, black 73 pin plug (X1), pin 50driver kick, harness to reardriver and passenger window switch, black 10 pin plug, pin 7driver window switch, gray 14 pin plug, pin 6passenger window switch, gray 14 pin plug, pin 6EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5brake switch or BCM, brown plug, pin 6parking brake switch or BCM, brown plug, pin 16horn switch or BCM, brown plug, pin 18BCM, brown plug, pin 20driver window switch, black 6 pin plug, pins 3 and 1passenger window switch, black 6 pin plug, pins 3 and 1left rear window switch, black 8 pin plug, pins E and Hright rear window switch, black 8 pin plug, pins E and Hsunroof switch, black 8 pin plug, pins 6 and 4driver window switch, gray 14 pin plug, pin 5radio, black 14 pin plug, pin 1radio, black 14 pin plug, pin 8radio, black 14 pin plug, pin 7radio, black 14 pin plug, pin 6radio, black 14 pin plug, pins 2 and 9radio, black 14 pin plug, pins 3 and 10radio, black 16 pin plug, pins 5 and 13radio, black 16 pin plug, pins 6 and 14radio, brown 16 pin plug, pins 3 and 11radio, brown 16 pin plug, pins 4 and 12radio, gray 16 pin plug, pins 1 and 9radio, gray 16 pin plug, pins 2 and 9radio, gray 16 pin plug, pins 7 and 15radio, gray 16 pin plug, pins 3 and 11radio, gray 16 pin plug, pins 4 and 11Digital Radio Receiver, black 16 pin plug, pin 16Digital Radio Receiver, black 16 pin plug, pin 9Digital Radio Receiver, blk 16 pin plug, pins 2, 1Digital Radio Receiver, blk 16 pin plug, pins 3, 4center of dashleft front doorleft front pillarright front doorright front pillarleft rear doorleft rear pillarright rear doorright rear pillartop center of dashunder front of center consoleunder passenger dash, behind glove boxspacer.gifspacer.gifPhotohas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifhas_item_photo.gifspacer.gifspacer.gifNotehas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifhas_item_note.gifspacer.gif
Nov 03, 2012 | Cars & Trucks
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
I am trying to find the wiring diagram for my 2002 FXD. I am installing a trunk and need to know the light wiring diagram in order to hook up the tail and turn lights on the trunk.
Jul 25, 2010 | Harley Davidson FXD Dyna Super Glide...
Help with Curious Village game on Nintendo DS
Hi Gill
For square 1, use pins 1 and 2 from row 1, and pins 1 and 2 from row 2.
Square 2 uses pin 1 from row 4, pins 1 and 3 from row 5 and pin 1 from row 6.
Square 3 has pin 3 from row 3, pins 2 and 4 from row 4 and pin 4 from row 5.
Square 4 is formed with pin 5 from row 1, pins 4 and 6 from row 2 and pin 4 in row 3.
Square 5 involves pin 3 from row 1, pin 5 in row 2, pin 2 in row 3 and pin 3 in row 4.
Square 6 has pin 3 in row 2, pin 5 in row 3, pin 2 in row 5 and pin 3 in row 6.
Square 7 uses pin 4 in row 1, pin 1 in row 3, pin 5 from row 4 and pin 2 in row 6.
Hope this helps and good luck!
Scott
Mar 25, 2010 | Nintendo DS Console
I can get 7 squares but I'm told it's wrong
SQUARE 1.= use pins 1 and 2 from row 1 and pins 1 and 2 from row 2!
SQUARE 2= use pins1 from row 4 , pins 1 and 3 from row 5 and pin1 from row 6
SQUARE 3= use pin 3 from row 3 , pins 2 and 4 from row 4 and pin 4 from row 5
SQUARE 4= use pin 5 from row 1 , pins 4 and 6 from row 2 and pin 4 in row 5
SQUARE 5= use pin 3 from row 1 , pin 5 in row 2 , pin 2 in row 3 and pin 3 in row 4
SQUARE 6= use pin3 in row 2 , pin 5 in row 3 , pin 2 in row 5 and pin 3 in row 6
SQUARE 7= use pin 4 in row 1 ,pin 1 in row 3 , pin 5 in row 4 and pin 2 in row 6.
Feb 24, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
What are the pin conections for external usb on an asus a7v400-mx board
USB mouse/keyboard to 5-Pin DIN or 6-Pin Mini-DIN adaptor USB Function 5 Pin DIN 6 Pin ps/2
Pin 1 +5V Pin 5 Pin 4
Pin 2 -Data Pin 2 Pin 1
Pin 3 +Data/clock Pin 1 Pin 5
Pin 4 Ground Pin 4 Pin 3
shield shield shield
Apr 16, 2008 | Computers & Internet
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
