Question about Air Tools & Compressors
Helo 2go i bought 2go credits for 3 rand and for 5 rands but it doesnt appear in my account please help
virgils
  • 39 Answers
SOURCE: Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Posted on Oct 11, 2008
dgjtex
  • 405 Answers
SOURCE: Ingesoll Rand 4000
http://air.ingersollrand.com/manuals/Default.aspx
Go here, If this helps you please vote me fixya..
thanks
Posted on Jan 31, 2009
  • 5 Answers
SOURCE: how long should it take to fill up 80 gal tank
10 to 13 minutes from 0 psi to max and auto-shutoff. Tank will be extremely hot, also. Hope this helps!
Posted on Jul 15, 2009
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
I have 1 black, 1 white and 1 green ground on pressure switch. ?
Black & White would both be 115v on a single phase 230 circuit, green would be ground.
Jul 20, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand M # 10T3NL Trouble
your problem seems to be that the non return valve is passing ,your local i/rand dealer can supply a new seal,there not expensive
Oct 08, 2008 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
23 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
