Question about D-Link AirPlus DI-524 Wireless Router
DOCUMENTATION DISCRIBING THE ROUTER MODEL FETATURE OF THE D-LINK di -524
    Champion:
    New Friend:
  • 219 Answers
Here is the user manual (PDF):
http://www.dlink.com/-/media/Consumer_Products/DWL/DWL%20922/Manual/DWL922_Manual_EN_UK.pdf
Posted on Aug 14, 2014
Benimur
  • 6966 Answers
SOURCE: Have D-link 704 router, can I connect the DI-524 to it also to add wireless?
Hi, I have not tried it myself with DLink but with LinkSys, yes it will work. It may take a little configuration tinkering but should work. However a few notes: 1. You should only have 1 DHCP server (both have this feature); 2. You can not have 2 identical IP address; 3. I suggest you make the 524 as the gateway and the 704 as a slave; 4. In effect you will connect 1 of the LAN port of the 524 to the WAN input of the 704; 5. You have to copy the WAN settings of the 704 to the WAN settings of the 524; 6. Or if you want to retain the 704 as the gateway, disable the identical features in the 524. I suggest you treat the 524 as a client of the 704. Hope this gives you some idea and work out for you as it did with my LinkSys. Goodluck and kind regards.
Posted on Aug 17, 2007
mewms_14904
  • 1027 Answers
SOURCE: method of connecting Dlink wireless router DI-524 to computer
On the back there should be a reset to reset to default settings.
Posted on Apr 04, 2008
melnavz
  • 1226 Answers
SOURCE: Drivers for DI-524 Wireless Rourter D-Link
You can find donwload here:
http://support.dlink.com/products/revision.asp
follow the instruction.
me this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on May 21, 2008
kakee
  • 1269 Answers
SOURCE: configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Posted on Nov 01, 2008
amusedgeek
  • 787 Answers
SOURCE: D-Link DI-524 won't resolve address
It may not be your router, it could be your computer.
Computers keep track of sites they have been to so that they don't have to do a dns request every time - makes things a little fast. Sometimes the cache can become corrupt or the IP address changes.
Hold down the Windows Key on you keyboard and press the letter R at the same time, a window will open, type in CMD and then click OK. A black window will open, please type:
ipconfig /flushdns
Now press the Enter key
Try going to your site now.
Posted on Jan 06, 2009
How to i setup this router "D-link DI-524
Link to router information, you need to select your model revision, then you will be able to download your installation guide, firmware updates, etc
ttp://www.dlink.com/products/default.aspx?pid=DI-524&tab=3
Mar 04, 2011 | D-Link AirPlus DI-524 Wireless Router
I am trying to us this router with my laptop and I have model #DI - 524. I need a manual to set it up. The router is a D-Link 802.11g/2.4Hz, Model DI-524
hxxp://www.retrevo.com/support/D-link-DI-524-Wireless-Routers-manual/id/420ci365/t/2/
Check to see if this is the correct model. If so, change the "x"s to "h" in the link. Not sure if I can post live links here.
Sep 05, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Does DI-524 spport WAP
It looks like the 524 will support WPA-PSK.
Try this:
http://support.dlink.com/faq/view.asp?prod_id=1506&question=DI-524
If your 524 doesn't look like this you amy need to update the firmware.
Good Luck
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router pass and username
Default IP: 192.168.0.1
Default username: admin
Default password: *blank*
Jan 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
me this help,
melnavz
PS:
May 21, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link di 524
You can find all the information on routers on the web link given below.
http://support.dlink.com/supportfaq/
I hope this should help you will the router information and troubleshooting on your own.
Have a great day.
Feb 12, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
80 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
