Hotpoint wdd960 washer dryer code f13 fault in respect of the tumble drier, its a nightmare new baby in the house! Just stop mid cycle any ideas? Thank you
Washer dryer code f13 fault stop mid drying cycle. any ideas? Thank you
4 Suggested Answers
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
beltronic205
  • 1467 Answers
SOURCE: Hotpoint WDD960 Washer Dryer - no error code but
Sounds like heating element is not coming on ..Heating first then with a Fan motor running and water flow the steam that is produced by the heaters are changed to water by the cold water over a condenser , the pump then puts his out to waste..
Posted on Jan 28, 2011
  • 118 Answers
SOURCE: hotpoint ultima WDD960, My washer dryer has
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Posted on Dec 31, 2011
Change heater element on hotpoint TVF770K Aquarius dryer now have F13 fault
There is a small thermostat button ontop of the Heater mechanism which has tripped . It has either a red dot or blue dot ontop. Use a pin or opened up paper clip and push through the red wax. It will go click and it is reset. .
It sometimes trips out with a F code which normally trips the machine off because it thinks the Heater unit is on fire.
There is a small disk which costs about £15 to buy which you can change.
You will need HEX screwdriver set to change and open up the Heater matrix to clean the fluff off the element.
Nov 19, 2013 | Hotpoint TVF770 Tumble Dryer
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are describing.you would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
When i set my drier to dry on high heat it keeps tripping the electric with error code f-13 please could you advise me on why this is thanks
Indesit (Hotpoint, Ariston) 'F13's refer to 'thermistor circuit fault', 'dryer fan not working', 'dryer NTC (thermostat) fault' and other similar things! There CAN be problems with poor connectivity between cables and plugs/ sockets which could cause similar symptoms. It realy needs a service call to identify/cure, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 16, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
WASHER GETS F13 CODE AT MID CYCLE
must be a washer dryer f13 means dryer htr faultcheck dryer htr and safty stat not open circuit
Nov 11, 2009 | Washing Machines
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
