Question about Fujitsu Siemens Computers & Internet
How to get boot menu scaleo p
How to get into boot menu
How do I add Boot devices to Boot Menu on Acer V5-122P which only shows the internal HDD
Because this is one of the thin client laptops all you have in the laptop is a Hard drive. and other boot device is a USB device that you plug in. As such the bios will not show it until it is plugged in and then you can select it to boot from.
Feb 10, 2015 | Acer Aspire V5-122P-0864 11.6" Touch...
This model is intregated with windows 8 you may boot other devices by enabling legacy mode but during this your original boot manager may removed after that you not be able to boot previous windows
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Mar 30, 2014 | Lenovo Computers & Internet
Boot scaleo p
boot into BIOS setup and make sure all USB-related settings are enabled, especially 'boot from USB' or 'legacy USB support'
Oct 13, 2013 | Intel Computers & Internet
Enter setup boot menu
When you turn your Acer on, there are some options in the very beginning that say "press F9 to enter boot menu" or "press F10" or "press F11" you just need to find out which of the F's is the key to the boot menu. When you already know that just click it 5-7 times while it's loading and you must enter the boot setup menu.
Aug 02, 2013 | Acer TravelMate 3270-6569 Notebook
Boot menu
Your computer's BIOS, or basic input/output system, regulates several important system functions before your operating system loads.
The BIOS can even tell your operating system which device it should load from, whether the computer's hard drive or a USB stick.
You can control this and other options from the BIOS boot menu.
If you own an Acer Aspire One netbook and want to access the boot menu, you can do so by entering the computer's BIOS.
Turn off your Acer Aspire One netbook.
Turn it back on.
Press "F2" when you see the Acer logo appear as the computer boots up.
This will open the computer's BIOS menu.
Press the arrow keys to highlight the Boot option.
Press the down arrow key to highlight specific boot settings to change.
also
Windows operating systems support a variety of boot options on the Windows Advanced Options Menu that allow you boot your computer based on your need.
They support boot options such as Safe Mode, which is generally best for troubleshooting and virus removals; or the Safe Mode with Networking, which allows to use an Internet connection while troubleshooting system problems.
Within seconds, you can access the boot menu and select the option that works well for the task you want to accomplish.
Shut down all currently running programs and restart your computer.
Press "F8" repeatedly before the Windows icon shows up on your screen.
This will bring you to the "Windows Advance Options Menu."
Scroll down and select the boot option you want.
Press "Enter."You can select from "Safe Mode" "Safe Mode with Networking" or your regular booting option.
Choose the boot option based on your need.
For troubleshooting, it is advisable to select "Safe Mode" because only a certain amount of drivers and resources run allowing you to resolve issues.
Jun 28, 2013 | Acer Aspire One D250 (99802378332) Netbook
Fujitsu scaleo j wont load passed the fujitsu siemans logo screen
If you remove the Graphic Card and replace the original Memory will it boot?
Jan 28, 2013 | Computers & Internet
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
Go to the device manager and delete device from it. Then plug in the device and let Windows define it again.
Computers & Internet Logo
110 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
