SOURCE: Venta-sonic VS 207 humidifier. Turns on but the
I had same problem and the fix was simple. Over the summer the water level sensor stuck in the "empty" position so the unit thought it had no water. Remove the phillips screw holding the components in and clean them and reassemble. This solved my problem and took 30 seconds to complete.
SOURCE: Venta Sonic VS205 Humidifier turns
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
