Question about Sharp R959SLMA 900 Watts Convection / Microwave Oven
R872 grill and oven stopped working, microwave and turn table ok
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: No Light No Heat Wacky Display
First of all, how old is the oven? It sounds like 3 separate problems, but I would doubt that any were caused by using the grill on the same circuit. Most often, that will just blow the breaker. Importantly, have you had any other electrical items fail in the last few months? Have you had an unusual number of light bulbs blow in the home, or have they blown much sooner than you'd expect? A "yes" to these questions could indicate a fault in your house wiring which must be quickly addressed by the power company or an electrician. Barring those complications, here are my thoughts: I would say the oven light just failed. It could have had its life shortened or ended due to door slamming. For the display to return to 95.00 instead of 00.00, I would suspect that the control dial is worn, damaged or contaminated by grease, dirt, etc., causing a slight shorting effect. 95.00 is the maximum cooking time - the extreme top setting of the dial. This kind of controller problem could also be caused by grease or moisture on the control circuit board. This is most likely to build up when boiling on the stove without first turning on the hood fan (a must) or if the hood fan has a clogged filter or restricted air flow in the duct work. It could also be due to spraying cleaners directly on the control panel / keypad instead of using a slightly damp cloth. Lastly, the lack of cooking operation is most often caused by (yes, door switches or door switch mount trouble) a loose connection at the magnetron, or a bad magnetron. First to address would be the cooking problem, and the first thing I would check is door switches and switch mounts. The lamp would just need to be replaced, but in most newer models, you have to remove the outer cover, which means taking it down from the wall. Safety dictates that this is a two-person job, and you might need to have your original installation instructions on hand to do it. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need to order any parts (other than a light bulb, which should be available at the grocery store) I would recommend Tritronics at http://www.wehaveparts.com If you have a problem with the controller, that would have to be professionally repaired. We do that for customers nationwide for $39.95 in most cases.
Posted on Jun 17, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Microwave oven controls do not work
You mean the turntable motor turns whenever the door is shut, even if you're not cooking?
If that's the case, then the problem would probably be a stuck relay (RY3) on the control circuit board, which we regularly repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If you have a different problem than I described, please reply back with details before you give us your rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
Posted on May 09, 2008
ginko
  • 19396 Answers
SOURCE: Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
Microwave blows fuse in microwave mode grill function ok
It is most likely the capacitor has shorted or the rectifier has shorted. Check with ohmeter, but make sure it is discharged first by shorting the capacitor with a wire.
May 21, 2010 | GE Advantium 120 Convection/Microwave Oven
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
Apr 21, 2010 | Microwave Ovens
Defective turn table (not working).
opening a microwave oven is not recommended at consumer level due to hazardous internal componants. Seriously hazardous.
Oct 27, 2009 | Sharp R-1214 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
MICROWAVE OVEN
Bad power diode, bad power capacitor or bad magnetron
Google on 'microwave not heating' and you'll get some sources of information
Dec 13, 2007 | Microwave Ovens
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Sharp R959SLMA 900 Watts Convection / Microwave Oven Logo
22 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
