Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
Baracuda works for only n little while and then the suction is gone, if you pull it, it will go for a few minutes before standing again
5 Suggested Answers
  • 366 Answers
SOURCE: My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Posted on Apr 08, 2010
  • 990 Answers
SOURCE: Can Baracuda Diaphragm be replaced?
If you can't find any junk in the diaphram or throught. The best thing to do is take it to a store they can show you how to do this and they will not usually charge for more than just the part.
Posted on May 28, 2010
Testimonial: "Thanks - I will take it in and have them look at it."
jharwell668
  • 640 Answers
SOURCE: I have a Zodiac Baracuda
It sounds like your house weights need to be adjusted. When the pool cleaner is resting, it should always sit at a 45 degree angle on the bottom of the pool. If it stands up on the front side, try sliding the weight away from the cleaner head. You may need to make several small adjustments to get the balance right, but this is almost surely your problem. Here is a copy of the users manual if you want to read more about hose weights and balance:
http://www.baracuda.com/resources/manuals/TL-2050.pdf
Posted on May 09, 2011
jharwell668
  • 640 Answers
SOURCE: MY Baracuda can be prompted
Check your Star Control settings to make sure that you are getting adequate pressure. If you get a blue or black reading, you are not getting adequate flow and need to increase (aim for the yellow zone). You will also want to make sure that you don't have any obstructions that are preventing movement (in the mouth of the cleaner or hose). If these are not the cause, I would make sure that you have assembled the cleaner correctly. Here is a copy of the users manual for these pool cleaners.
http://www.baracuda.com/resources/manuals/W83309.pdf
Posted on May 11, 2011
Zodiac mx8 wheels are not turning
Hey Sergio,
If they wheels are not turning, the A or B side direction control has quit working. Normally they have drive 1 shaft in each run that wears down over time, losing friction on the shafts for the wheel to make the wheel rotate. If one side has gone out, I'd recommend replacing both and take a look at your wheels also. Normally these all wear out around the same time.
You're looking for something like this:
https://www.amazon.com/Baracuda-R0524700-Direction-Control-Replacement/dp/B00C404KFA/
https://www.amazon.com/Baracuda-R0524800-Direction-Control-Replacement/dp/B00C404LE0/
https://www.amazon.com/Baracuda-R0525100-Assembly-Replacement-Suction-Side/dp/B00C404LD6/
https://www.amazon.com/Zodiac-Baracuda-Swimming-Cleaner-R0526100/dp/B018GZEA7E/
Sep 14, 2017 | Zodiac Pool & Spa
Baracuda stopped working. it is not vibrating but not moving
it ended up being that the hose had a kink in it. It's working fine now.
Feb 05, 2013 | Pool & Spa
I have a Zodiac Baracuda G3 pool cleaner once the the pump switches off at night the next morning creepy does not sit flat on the bottom of the pool the front side stands up in the the air if you lift the...
Oct 11, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a G3 and it will work for a few minutes and then stop. There is plenty of suction, so i am not sure what to do. It came with the house i bought a few years ago. I have the hoses and the G3 without...
This sounds like a bad diapraham, These can be gotten at your local pool store and if you bring the head with they can install it at the same time. They can ck the unit for you at this time but if you have good suction and flow this is probally your problem.
Jul 19, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
79 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
