Jvc tv says no channels have been added yet. Please go to the install and retune menu to add channels
2 Suggested Answers
  • 22 Answers
SOURCE: retune with oneforall remote
look for a menu button and try to find install and retune on the menu
Posted on Mar 03, 2013
I have jvc tv model LT-24C660, I turn on tv massage come “no channels added yet. Please go to the installation menu to add channels.” How can I go to installation menu?
Do you have cable or satellite? Satellite uses only one station and all you have to do is select the station your satellite provider told you to use. If it is cable then go to your menu screen and look for "setup." That should get you going.
Nov 22, 2017 | JVC Televison & Video
I have a finlux 32 in 3d tv the probi get is wh tv on i am get this no channels have been added yet please go to install and retune menu to add channels i cant even switch tv off with remote
are the remote batteries ok, fit a new set and retry , click on menu go to settings , click on country if asked, click on automatic tuning, make sure there is a good signal at the aerial ,it may take a while , to tune in all the stations.
Nov 12, 2016 | Finlux Televison & Video
How do you tune TV
A full retune should only takes a few minutes and can be done with your remote control. Here are some guidelines for how to do it, but bear in mind every model of digital TV or box will be a little bit different.
  • Make sure your Freeview TV or box is on and in digital mode, usually by pressing the DTV or digital button on your remote. Then press 'menu'.
  • Select the 'set up' or 'installation' option. If you see picture icons, select the tool box, satellite dish or spanner. If you are prompted for a code, try 0000 or 1234.
  • Select the full retune option. This is sometimes called 'first time installation', 'factory reset', 'default settings' or 'shipping conditions'. Do not select 'channel update' or 'add channels'.
  • Press 'OK' if your equipment asks if you want to delete all your channels. Don't worry this is normal
  • Channels will automatically be installed. This may take a few minutes and your equipment may shut down and restart
  • In some cases, where transmitter signals overlap, it may be necessary to carry out a manual retune.
Note: Depending on your TV equipment, you may need to update your favourites list following a retune. Some digital recorders may require scheduled recordings to be reset.
Jun 10, 2016 | Televison & Video
I had Losty remote and all the TV says is "no channels have been added yet please go to the install and retune menu to add channels" all I want to do is play Xbox but I don't know how to do it
Check to see if there are any on board keys or buttons. There should be one that takes you to the menu or one that reads Source or Input. Press it or tap it, depends on the type of keys, until you get to the despite input, where you connected the XBox.
Feb 19, 2015 | Televison & Video
How do I add channels using the remote?
YOu cannot ADD channel to a CRT TV anymore because Analogue transmissions no longer prevail.
You must use an HDTV digital set top box connected to the antenna input. These have an "Auto tuning" facility which you access from the MENU options. Any new channels which come into being will automatically be added into the memory of the set top box. You just need to remember to do a retune every so often to find out if other channels have come "On Air".
Jan 17, 2015 | Televison & Video
Retune with oneforall remote
Mar 03, 2013 | Televison & Video
Have just moved house .....have retuned tv ....but cant get any BBC channels
Automatic scan cannot detect the BBC channels, possibly because they are too weak in your new location. It should be possible to add channels manually by using your remote. The setup function of your TV may give you the option of adding channels manually
Oct 14, 2012 | Grundig Televison & Video
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Televison & Video Logo
220 people viewed this question
Top Televison & Video Experts
Electro Med Services...
