Question about Sunbeam 2386 MixMaster Series Stand Mixer
Frayed power cord to replace - Sunbeam 2386 MixMaster Series Stand Mixer
    Habit-Forming:
  • 23 Answers
Power cords are available at NelsonEZY.com. NelsonEZY com home page
Posted on Jun 15, 2014
I have a Sunbeam stand-up mixer, theccord is frayed,how do I replace it model number is 11c
Nelsonezy.com has some basic instructions for changing the power cord.
Oct 23, 2016 | Sunbeam Food Mixers
How to replace power cord?
Replacing a power cord is fairly straightforward for those who already have a little experience.
The power cord is either obtained as an assembly as a spare part for your machine or bought as a simple length of cable from the local hardware or electrical shop. If the strain relief grommet is moulded onto the cable an assembly will probably be needed.
Carefully removing the existing lead will provide a pattern with the correct dimensions to cut the replacement, remove the insulation, etc.
Appliances use a variety of methods of connecting the power cord into the internal terminal block but which screws to remove is usually an intuitive process.
Jan 23, 2016 | Food Mixers
Why is mixer not working?
Double check power at outlet or try another outlet with known power. Check the plug and cord connection. I recently had to replace my toaster cord because the cord at the plug had separated one of the wires. May be a switch or a safety device.
Jul 05, 2015 | Food Mixers
Kenwood kmix shocked me when i touched the body ...
Stop using it. If the insulation on the power cord is cracked, cut, or bare, you are getting a short from a wire being exposed to the mixers body. This could cause a Fire and/or injure you directly. The source needs to found by a technician and repaired.
Mar 24, 2014 | Food Mixers
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Kitchenaid k5a
These mixers last for years and years. Aside from the fact that you could have a FIRE from a frayed electrical cord, interruption of power to the motor can cause additional problems. Get the Manual with all of the details on repairing the unit. Replace that power cord NOW! When the Housing is open, take a tooth brush or stiff paint brush and whisk out the debris collected inside over time. Check the contacts on the speed selector and look for any black deposits or surface material that may be there.
Mar 10, 2014 | Food Mixers
Power cord for GE hand held mixer
I have a gold mixer also, My wife loves it. The cord went
and was unfixable. I found one on this website abtecparts.com.
The cord was $5.99 plus shipping. Good Luck
Pat
Mar 18, 2009 | Food Mixers
Need to replace cord on vintage Sunbeam Mixmaster Junior
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
Mar 10, 2009 | Sunbeam Food Mixers
Sunbeam 2386 MixMaster Series Stand Mixer Logo
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
