Question about Yamaha Music
Yamaha mdf2 floppy disk drive
Mdf2 floppy disk drive malfunction spins but does not read disk
3 Suggested Answers
  • 1137 Answers
SOURCE: not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Posted on Apr 23, 2009
SOURCE: my yamaha psr540 play button not functioning,
received a keybord without manuel dont know how to start it
Posted on Dec 16, 2009
Sy85 floppy drive
It could possibly be the drive belt on your disc drive. The original drive used on the keyboard was not direct drive, over a period of time the belt wears and either slips or perishes. You might think it is still working as the motor spins and sounds as if there is life.
Take the drive out and look under the drive to see if belt is there if not replace.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idProduct=18842
Belt should go around black disc and brass capstan.
Apr 04, 2014 | Yamaha Music
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
Jan 17, 2014 | Korg Pa50 Professional Arranger Keyboard...
I have a disk not ready sign on screen, floppy disk receiver has being replaced three times; old and new floppy disk tested; cable has continuity... I do not know what else can be
The floppy drives of this age often required strapping to select the unit number and other setups. Newer drives were not compatible. Make sure the drive selected light remains on when power is on. If not, check the drive selections jumpers for the drive.
Feb 03, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
I own a Korg Triton Classic. I just replaced the touch screen on it. Now it wont read the floppy disks...any suggestions
It is VERY easy to not have gotten the cables back and seated completely for the floppy disk. ALSO it is very easy to damage the ribbon cables on floppy drives by pulling at the edges of the ribbon to pull connectors off. One MUST distrbute the force all across the cable as it is easy o damage the connections in the connector for the wires near the edge. It is also easy to damage the pins on floppy drive connectors. You will need to reopen the unit and check the cables INCLUDING the little power cable to the drive. If you have damaged the ribbon cable you can either replace it or possibly get another connector and put it on the cable right next to the one with the problem and crimp it in a vise... These are an insulation displacement type so you need to get it on straight and ALSO verify the index is the right direction before crimping. For your problem think cables, cables, cables...
Jan 26, 2011 | Music
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
When you turn on the wk 3000 the lcd reads pls wait after a few minutes it goes blank no sound no responce
This ONLY applies if you have a floppy or hard drive in your unit...
SOME of these synths hang up during boot if the floppy or hard disk isn't recognized as working...
Also verify your power adapter is producing the right voltage and is the original.
Jul 19, 2010 | Casio Music
When I load a floppy with music styles into the
Not sure about your particular keyboard, but on the Yamaha Tyros the style will NOT start rhythm until you select start AND hit a chord.
The style doesn't know what chord to start with until you trigger it.
SOMETIMES the style has to be moved to a user space...
One has to read and then DECYPHIER how to work these synths... Spend a little time with the user manual, as hard as it is to understand.
Jan 12, 2010 | Yamaha Music
Not reading my floppy disk( MPC 2000xl by akai)
Mar 20, 2009 | Music
Floppy disk drive
It needs no further fixing now.
I rebooted the keyboard as suggested by the FAQ then reformatted the floppy in the computer. I tried a recording which it then played back fine. It also acknowledged the title of the song as 001song as normal.
Thanks for the chance to air the problem though.
Nov 09, 2008 | Yamaha Portable Keyboard with 61...
Open Questions:
Music Logo
53 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
