1. As soon as a situation involving a dangerous individual becomes evident and you have assessed the situation, you should:• ________________ (Select the missing action from below.)
  • kakima Feb 16, 2014
    Would you care to complete the question?
Why is there brown thick liquid coming out or my iron,when I use the steam
Very dangerous situation. Rusted parts inside give the water that particular colour. Change the iron asap (as soon as possible), otherwise all your clothes will be the same colour.
Sep 11, 2017 | Irons
Explain how a working relationship is different from a personal relationship
Hello there!
A "working relationship" would (usually) refer to a situation where you've become acquainted with a person in a workplace environment.. when the majority of your communication / interactions with the individual are usually work-related, and don't involve any "deep, personal feelings", which could possibly hinder you in going about your workday.
A "personal relationship" would be when you've met a person in a casual setting, or a chance encounter.. You both start talking and find that you either share a lot of interests / hobbies in common or that you really just feel very close and comfortable around this individual.. A relationship like this could likely lead to a life-long friendship, or perhaps a marriage, etc.
This is not to say that a "working and personal" relationship can both happen at the same time.. on the contrary, there are a LOT of great friendships, partnerships and marriages which have started due to working with someone.. over time, a closer bond is formed with a person from working closely with them.. you get to know them simply from interacting with them on a daily basis, etc.
I hope this helps! I wish you the best!
Apr 13, 2017 | Personal Computers & Internet
How Much Time Does The Working Capital Loan Process Take?
As soon as the lender has executed the initial assessment and taken an application from you, he can submit the loan and have a solution for you within five working days or less depending on the intricacy and structure involved.
Nov 15, 2016 | The Computers & Internet
Brakes juddering
studdering? Have them checked. Disks could be worn and need to be replaced. If the disks are worn, you should do this soon as it is a dangerous situation.
Mar 07, 2016 | Cars & Trucks
I have a noise in the clutch housing on a caseih 485tractor is it the throw out bearing
throw out bearing noise is from when the bearing is under load. If it is idling and there is no noise but the noise comes as soon as you start ty press the clutch pedal then it is the bearing Tractors run a shaft within a shaft to run the pto and it is sometimes the bearing for the shaft in the shaft(tube ) that fails and allows the shaft to hit on the tube
run a series of test situations and it will become evident as each test is done ( clutch out , clutch in, clutch full in , clutch half in for pto etc.
Mar 04, 2015 | Cars & Trucks
What are the methods for evaluating learning and facilitation in outcomes based education
This involves gathering evidence of the students' abilities and knowledge, using a variety of methods directly related to the performance or outcomes which are required of a competent learner.
So if you were assessing a spray painting student, you would observe samples of the student's work, and also the student preparing for and carrying out the necessary tasks over a range of required outcomes.
You could assess any theoretical knowledge needed via an oral interview, or a written test (IF the student had the required writing skills already, you are not assessing that).
Colour discrimination could be assessed by asking the student to match several samples as closely as possible, or to mix up a matching paint pot.
And so on. Outcomes based education is distinct from Inputs based learning, where an approved syllabus is studied, teaching materials are often standardised, tests are sometimes unfair, and no great emphasis is placed on the abilities and knowledge required for a specific workplace. Therefore a lot of knowledge has to be gained later by experience.
Sep 03, 2014 | Computers & Internet
What is the use of over-glaze?
Over-glaze allows pottery to become a piece of art, making it truly beautiful. Applying over-glaze can be dangerous due to the chemicals involved in the process.
Feb 03, 2013 | Crafts & Hobbies
Is co2 in coolant dangerous?
it is hard to know if there is any damage to the cylinder head without having it checked. you are doing the RIGHT thing by having it checked.
Sep 03, 2012 | 2004 Mini Cooper
Only get the screen mpc tm
If i understand you correctly, the MPC logo comes on the screen and nothing more. If that is the case the problem is a hardware issue or windows files have become corrupted. If you have the recovery disc attempt to re-install your operational system, if that fails I suggest a professional to assess the situation.
Mar 09, 2012 | MPC Computers Computers & Internet
The DVD will not keep the tuned channels as soon as i go to standby it loosed the channels and i have to retune.
The tuner in this model usually incorporates a microprocessor to store the channels in its 'memory'. It would be part of the tuner/decoder circuit. When this chip develops partial failure, preset channels or stored functions are erased from memory, resulting in retuning frequently. Unfortunately, this is not serviceable to the consumer at individual component level; it would have to go to an authorised SONY service centre, for assessment.This could prove expensive, so obtain a quote on the likely repair cost(s) involved, then make a decision afterwards. Up to you; the purpose of the quote is to
A) give you an estimate on likely repair cost(s) and time involved;
B) offer you a second opinion which will outline the real problems and determine whether this is economical to repair if it is fixable and/or parts/boards are available.
DVD recorders and players use more than one microprocessor, and each of these are surface-mounted devices, glued and soldered to the copper side of the PCB. Only accept the quote if you truly want this repaired professionally by a SONY tech. and are prepared to pay whatever cost(s) necessary to restore this unit to full functionality, including remembering settings/channels.
May 12, 2011 | Sony RDR-GX300 DVD Recorder
148 people viewed this question
jasbo
jasbo
