Question about Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer
I can't get out of downscan mode to conventional mode for the full sonar menu
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
How do i disable the depth sonar
There is a selection either under sonar options or the main menu sonar tab that allows you to turn the sonar off. Article Details
here is a link to Lowrance to download your users manual in a PDF format.
Oct 17, 2014 | Lowrance Elite-4 DSI Combo with 455/800kHz...
Works on down scan but not on sonar
Hummingbird systems have the ability to turn off pages so they will not be displayed. On your main menu look for the "views" tab. Scroll down to the sonar view page and see if it shows visible or hidden by that page. If it says hidden, select visible and you should be all set.
Oct 01, 2014 | Humminbird 1158c Di Fishfinder With...
Can not get my HDS-5x and structure scan to interface
ooooooooook click menu button twice go to functions scroll down to structure scan see if the circle beside it is high lighted if not click on it to turn it on do this to both units
Mar 25, 2013 | Lowrance LSS1 StructureScan Sonar (Lss1...
I cant get any output in sonar 6 ahd yes the rack is active im new to sonar just the mixer xenyx xl 1832 usb
Make sure Sonar is set to use the Xenyx for the clock in the audio options pull down menu. It often defaults to your PC soundboard.
Sep 23, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
Drivers Disappear
Its a fight between 64 and 32 bit versions. Audio codec is not so compactable with your sound card sysaudio file You need an updated driver which is compact-able with direct x latest can solve your problem
Jun 19, 2008 | Compaq Presario 700 470024-192 Notebook
Lowrance Elite-7 Hdi Sonar/Gps Combo, Model 83/200 Ducer Logo
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
