Question about Philips New SHB6110 Bluetooth Stereo Headset Headphones
What is the voltage and mah size for philips shb6110 headphones
3 Suggested Answers
brector3
  • 1624 Answers
SOURCE: What are the specs for the single AA sized
You will find the correct Philips battery for model 8175XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/norelco-philips-8100-series-liion-battery-cell-p-578.html
Posted on Jul 24, 2010
Testimonial: "Exactly the answer I was looking for. Ordered one today as a direct result of this information. Thank you for your help and "fixya" for being there."
rockmeister
  • 2047 Answers
SOURCE: can not 550 mah rechargeable
Sorry but i dont understand the question. Are you looking to replace the batteries or they will not recharge?
Posted on Oct 10, 2010
I have WeSC headphones. They are Banjar on-ear headphones, wired in. There are no visible damages. No sound at all. I don't wanna cut anything until I know what's wrong. Anybody have ideas?
Try getting a headphone amp. Battery powered and make sure you get one with no less than 3000 mah capacity.It will last more than 24 hours with 3000 mah.If more power does not help check wire connections in the headphones.
Jun 27, 2016 | Wesc Audio Players & Recorders
Were could I buy sponge for headphones shb6110?
Measure the diameter across your headphones from edge to edge using millimeters. Once you have that, you can go through these results and should be able to find one that matches.
31results for headphone cushions padding sponge
Aug 29, 2014 | Philips New SHB6110 Bluetooth Stereo...
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
I have a toshiba m100 and i want to connect it to my tv i have a hdmi output on my tv i am getting a picture but no sound what do i do
You will have a connect a cable from your laptop headphone jack to your audio in on your TV. This is a common problem. They sell a cable that goes from headphone jack to RCA jack size. You could also just add powered external speakers to your laptop and get excellent sound that way. I have a $20 pair of external Labtec speakers and they sound great watching a movie on TV.
Mar 06, 2011 | Toshiba Satellite M100-S5211TD (4400 mAh)
I have Philips go gear i pod it requires 1.2V AAA cell but i don't about current ratting plesetail me current ratting.
You don't need to worry about current rating, if you are using alkline batteries just replace it when it goes flat.
All AAA cells are a standard physical size, if you are using rechargeable cells then get the one with the highest amp hour rating.
I suggest you get nickel metal hydride battery, the highest capacity I've seen is 900 mAh rating.
Oct 16, 2010 | Philips Audio Players & Recorders
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
WHICH VOLTAGE HAS THE 2 BATERY PHILISHAVE TYPE HQ 6740/A
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
May 21, 2009 | Philips Philishave Cool Skin HQ6740...
Philips New SHB6110 Bluetooth Stereo Headset Headphones Logo
32 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
