Question about Riccar RC1100 Compact Vacuum
Riccar RC1100 replace power cord
I want to replace the retractable power cord on my Riccar RC1100. I assume I have to unscrew the two deep-set screws on the bottom of the cannister. But they don't seem to be Phillips or standard head screws... it's hard to see, as deep as they are, but it appears they may be hex-head. But I'm pretty sure a socket would not fit in those narrow holes. Does it require a special tool? thanks, Greg
4 Suggested Answers
  • 25 Answers
SOURCE: riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Posted on Mar 26, 2008
Bob Gemmell
  • 209 Answers
SOURCE: HAVE A RC1400 THAT WON'T RUN.
Should be size 15 or 20 torx bit screwdriver required
Posted on Aug 21, 2009
SOURCE: Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Posted on Oct 12, 2009
Riccar 4000 series. Need to replace power cord. How do I get to motor? Do I need special tool because some screws are deep & have small opening so can't see screw head type.
One screw on back of handle will allow handle to slide off with some force. Two screws on front above bag door will allow small cover to come off allowing access to where cord connects inside vacuum.
Jan 19, 2016 | Riccar Vacuums
Replace power cord on riccar 8955
Remove the bag door cover, remove the screws holding the cover over the switch and wires coming into the body of the vacuum. Remove two screws holding the cord in place, unhook the old cord and install the new one the same way the old on was
Apr 14, 2014 | Riccar 8955 Upright Vacuum
Riccar 8955 power cord replacement
Remove the dust compartment door to gain access to the cover over the wiring and switch compartment. Remove three screws to gain access to be able to remove the old power cord and slide it through the hole in the back of the vacuum. Put new cord through the hole and wire back up as it was before.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
Riccar sunburst vacuum wheel
There are little prongs that hold the wheel on. New wheels are inexpensive if it needs to be replaced. Break the prongs off with a skinny screwdriver to remove the wheel. The new wheel will just snap in place.
Nov 15, 2013 | Riccar RC1100 Compact Vacuum
Oct 09, 2009 | Riccar Vacuums
How do I find the opening to change the bag on the Riccar RC 1100
Just above the hole where the hose goes there's a squarish part to where your hand should go. It should just pull upwards.
User manual download (FREE and in pdf form:)
http://www.riccar.com/ftp/whitepapers/1100_OwnersManual.pdf
Jun 17, 2009 | Riccar RC1100 Compact Vacuum
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Riccar RC-1100 won't power on?
try a different power cord, otherwise it is a thermal issue. if it is a thermal issue, call or e-mail tech support, and send it in. otherwise you could get it repaired @ any local vacuum cleaner dealer
Apr 07, 2009 | Riccar RC1100 Compact Vacuum
Riccar rc1100 won't turn off
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Vacuums Logo
27 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
