Question about Champion G5NG853S Household Juice Extractor
Can't get blade unit on shaft of Champion
My juicer is 20+ years old. I haven't used in a while. Also because I tried it one time recently and had great difficulty removing blade unit, had to pry off with blade end of a small axe. Now the shaft turns and I can't seem to like up the blade unit with the flat edge on the shaft to get blade/mastication unit on. I have lubricated with olive oil. Is that the correct oil? Or coconut oil. But shaft keeps turning. Most frustrating.
4 Suggested Answers
SOURCE: cleaning inside the cutter
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
Posted on Feb 05, 2009
  • 69 Answers
SOURCE: cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
Posted on Feb 07, 2009
SOURCE: Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
Posted on Apr 18, 2011
Overheating champion juicer
to the person. champion juicer running hot. if your blade is dull it will run hot bcuz its harder to turn and gets clogged easy. look online for new or less used blade.
Jun 13, 2014 | Champion G5NG853S Household Juice...
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
Cleaning inside the cutter
Jan 30, 2009 | Champion Juicers
Cleaning inside shaft of champion juicer cutter
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
Juicer no longer works !
the motor uses a tiny fuse in the windings and it might be hard to find and rated up to 15 amps... it blows sometimes for no reason and especially on cold starts.
also the on-off switch wears out.. and lastly the ac cord breaks inside from stretching too much.
Jan 30, 2008 | Champion 2000+ Household Juice Extractor
The shaft
Use steel wool to clean it, then be very diligent about putting olive oil on.
Dec 17, 2007 | Champion G5NG853S Household Juice...
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Champion G5NG853S Household Juice Extractor Logo
41 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
