Question about Casio Exilim Card EX-S100 Digital Camera
Auto focus problem of casion exilim camera - Casio Exilim Card EX-S100 Digital Camera
3 Suggested Answers
SOURCE:
  • 374 Answers
SOURCE: Auto Focus not working
First off your blinking battery light means you have a faulty battery and you need to have that replaced. Call tech support and they will replace that for you. Once that is charged up all the way then hopefully the camera will work properly for you. If not try resetting it.
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: Casion Exilim EX-S880 Charging Error
We had this problem - it occurred after the battery was totally discharged. Happened 3 times when battery was left in camera for an extended period and completely discharged, would not charge again. Keep at least a little charge on the battery, or remove from the camera for extended periods.
Posted on Nov 30, 2009
How can I make the focus ring work on my casio exilim ex f1?
The manual (pg 43) says that each time you press the FOCUS button, it will advance between Auto (AF), Macro (Flower), Infinity (Sideways 8) and Manual (MF). You can use the < or > keys to focus , or the ring if set up as described below:
Next, the focus ring can be programmed (pg 85) by pressing [REC] -> [MENU] -> [REC Tab] -> [Ring Setup]. Choose "CS fps" for Continuous Shutter Speed (pg 46), "Zoom" (pg 40), "Focus" (pg 43), or "Off" for no function at all.
You can download your manual here.
I f this was helpful, please rate it 4 thumbs up. Thanks!
Sep 22, 2011 | Casio Exilim Pro EX-F1 Digital Camera
The camers will not focus properly either on auto or manual focus
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Aug 02, 2011 | Casio EXILIM ZOOM EX-Z70 Digital Camera
My CASIO EXILIM camera wont forcus or keep the right exposure!
The focus frame does not appear on the monitor screen while following conditions.
• In the Auto mode, while the following settings are configured.
- Face Detection : ON
- Effect : Make-UP
- Auto Shutter : Detect Smile
• "MF" or "∞" selected for the focus setting.
• BEST SHOT scenes that use the above settings.
Example: "4 Portrait" BEST SHOT scene
* Changing the above settings will cause the focus frame to reappear.
If your camera wont keep the memory settigns after turn off the camera, its possible that you have some problem with the internal battery and need to be replaced.
Mar 07, 2011 | Casio EXILIM Zoom EXZ2000 Digital Camera
Clean your connecting areas with alcohol . If that dont work . It could be a bad battery
Aug 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Very blurred image as if it were out of focus
Touch auto focus on your screen.!!! or go to SCREEN control and change the screen size.
May 21, 2009 | Casio Exilim EX-Z750 Digital Camera
Infinity focus isn't working anymore
ahaha.... never mind. I was dinking around with it again and turns out, infinity focus only works if facial recognition is on... why, i don't know.
Apr 10, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Jun 14, 2008 | Casio Exilim EX-S600 Digital Camera
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
Casion exilim ex-z57 camera lens error
I HAVE THE SAME PROBLEM. MY SHUTTER IS SLOW AND I CANT ZOOM IN OR OUT BECAUSE IT WILL THEN SAY 'LENS ERROR'! I DON'T KNOW WHAT TO DO. I CANT TAKE PICTURES PROPPALY, THEY ARE BLURY. WHAT SHOULD I DO????????????????????? HELPP MEEE
Dec 22, 2007 | Casio Exilim EX-Z57 Digital Camera
Why are my flash images out of focus?
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Casio Exilim Card EX-S100 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
