Question about Welding Tools
Have a 71 miller big 40 won't ark and no power out of plugs put a new ingniter on welded for an hour then shut it off when back the next day and it wooden weld ageen S\N HE802998
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Hi, you have 2 big resistor with ajustable tab on it,check for visual damage on it and rusted connector or tab,
replace tab at same place if you disasemble it
Posted on Feb 22, 2014
5 Suggested Answers
  • 7 Answers
SOURCE: Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Posted on Feb 04, 2009
  • 5 Answers
SOURCE: I HAVE AN OLDER MILLER BIG 40 RUNS BUT NO WELD OR
check the ground ,make sure is tight.look around the machine and see if theirs a switch or a nob to turn from mig to arcweld...
Posted on Nov 26, 2009
  • 81 Answers
SOURCE: Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Posted on Jul 20, 2010
luis_david
  • 407 Answers
SOURCE: miller big 30 d wont weld
Probably your machines overloaded. Check your fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Check your owner's manual for more info about fuse replacement.
Posted on Aug 05, 2011
1971 Big 40. Where can I get brushes?
try electrozad supply,waffles electric,windsor factory supply,praxair welding supply,liquid air welding supply,future weld supply good luck
Apr 25, 2016 | Miller Welding Tools
Miller trailblazer 275 stalls after about two hours of welding.....
there is a voltage regulator directly above the electric fuel pump on this welder, make sure the three connectors are making good contact, there are three wires attached to it, the center conductor is either violet or blue, if the spade terminals are not making proper contact your machine will shut down as you state
you may also have a "sticking" or faulty fuel stop solenoid
if after you remove and check the connectors at the voltage regulator, the problem persists, locate the local Kohler dealer, your engine has a 3 year warranty for parts and labor
Feb 11, 2015 | Miller Trailblazer 275 DC Welder Generator...
No power from welder
Same as "my car won't start" Gotta start finding then problem. If I had a magic wand, I'll help you.
Sep 04, 2014 | Miller Big 40 CC/CV
I have a Miller Bluestar 185. Will not start with key. Put a new battery in it and it pull starts fine but won't with elec start?
check if 12v go on solenoid of starter when you turn key to start,mesure 12 v on starter when you turn key to start
if voltage drop to few volt,wire or connection are bad
Oct 31, 2012 | Miller Welding Tools
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
Have a Miller big 40 welder and the engine won't turn over
I'm not familiar with this particular unit--do you mean to say that the cooling system froze during the winter? If so, and the engine has overhead valves, the cylinder head, block, or both may have cracked causing water to leak into the cylinders which would have rusted the rings and cylinder walls (together). You are looking at major overhaul or even engine replacement (not what you were hoping). Good luck!
May 12, 2010 | Welding Tools
I HAVE AN OLDER MILLER BIG 40 RUNS BUT NO WELD OR AC POWER
Oct 25, 2009 | Miller Welding Tools
Miller syncrowave 200 makes buzzing noise from spark gaps.
Odd noises other than the normal sound of the spark gap working are often the result of dust and junk inside the case of your welder. That it also bogs down when it gets warmed up (fan comes on), also points to a need for some "annual maintenance" stuff being done.
Completely isolate the machine from the building power supply, pul the plug, open the circuit breaker, do whatever it is that makes the machine have no connection to any power.
Take off the covers with a 10mm or 3/8 inch socket (can't remember which)
Use a shop vac to **** out all of the dust and debris out of the machine. Low pressure (40 psi) air can sometimes be helpful to dislodge caked on dirt. Avoid any metal tools near the capacitor bank inside the welder.
Wipe off the fan blades.
Clean the spark gap electrodes by inserting and removing a matchbook cover, a business card, or a piece of white cardboard several times. Inspect the electrodes and adjust them according to the manual that came with the welder.
Check all of the power wiring connections for tightness by gently tugging on them. Look for signs of overheating on the power connections and on the internal connections to the welding terminals. Check the range switch for heating too.
With the cover still off, reconnect the power and turn the welder on. Look for obviously vibrating laminations on the main input transformer. If you see one buzzing back and forth, or if you notice lots of wear and tear on the varnish coating of the laminations, shut everything down and repair the loose laminations with some anti-fungal high voltage varnish.
Turn the welder off, disconnect the power, and put it all back together. Then turn the power back on and weld something, if htere is still a buzzing noise you'll need a Miller tech to solve the problem, you likely have a bad input transfirmer.
Regards,
Carl
Dec 16, 2008 | Miller Syncrowave 200 Tig Welder Cover...
Welding Tools Logo
149 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
