Question about Electrolux EIFLW50LIW 4.2 Cu. Ft. Front Load Washer with IQ-Touch Controls in
Electrolux MEX731CAS1 dryer stopps about 15 minutes after start, and won't allow the switch to be turned on.
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
https://www.youtube.com/watch?v=uMFpFVOFE5M
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ...
www.city-data.com > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 | Dryers
I was drying my clothes and the steam feature would not turn off. How do I turn off the steam feature ?
Hi friend, thanks for your post!
I understand that the steam feature on your Electrolux dryer is not turning off. I would recommend a reset and you can do that by disconnecting power to your dryer for ten minutes. I hope this helps. -Matt
Sep 21, 2014 | Electrolux Dryers
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Frigidaire dryer duzzes when start button pressed or starts but stoppes after a few minutes
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FDE336RES0, buzzes when the start button is pressed. I also see that it starts then stops after a few minutes. I suggest checking the cycle selector and making sure that it is not loose or has not come off. If this is not the case, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire Electric Dryer
Electrolux cde7700lw0 dryer
Good Afternoon Brain, this is Z. I am happy to assist you!
I understand that your Electrolux dryer (CDE7700LW0) door indicates it is open and your dryer will not operate. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your dryer. Select a normal cycle and verify if the dryer will start. If your appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Apr 10, 2014 | Electrolux EIED55I Dryer
Model Number: mex731cas1 Brand: Electrolux Age:
Hello Tuomas, thank you for allowing me to assist you!
Based on the video you have provided, it shows that your laundry center is experiencing one or two things, an issue with the water valve or a faulty timer. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. I hope this information helps to some degree.
Best regards!
Oct 22, 2013 | Frigidaire FEX831CS Top Load Stacked...
Electrolux washer dryer ewd 1409 start and pause light keeps flashing
That is a generic error code - please reset the unit at the household circuit breaker for about 10-15 minutes, and then retry the unit. No difference - please consult a professional.
Aug 22, 2012 | Electrolux EW1000i Front Load Washer
Why does the inside light stay on and the Kenmore dryer won't start when the door is closed?
There is a switch in the door jamb that turns on the light and also allows the dryer to start. If you close the door and the light does not go off like it did before, then that switch is probably bad.
Aug 29, 2011 | Kenmore Dryers
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Electrolux EIFLW50LIW 4.2 Cu. Ft. Front Load Washer with IQ-Touch Controls in Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
