Question about Whirlpool LEW0050P Electric Dryer
Wirlepool cario platinum electric dryer does not heat
My dryer will not start and the dash reads sencing
Try unplugging it for a _full_ 24 hours. Then plug into wall and try it. If still having same problem, it is probably a bad computer board.
May 18, 2015 | Whirlpool WED8600YW Cabrio Platinum High...
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Dryer turns on and blows, but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 27, 2010 | Bosch WTMC632SUS Platinum Series Nexxt...
Kenmore dryer not heating up
heatman101
Nov 15, 2010 | Electrolux AEQ8700F Electric Dryer
LER4634J Electric Dryer: dryer will not heat...
heatman101
[p]
May 17, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
