Question about Neff Daily Watch
The watch just stopped working one day
Ive tried putting an new battery in and that didnt do anything. The minute hand just releases and swings freely sometimes but not all the time.
Tissot lelocle is loosing too many seconds a day and second hand jumps several times between second 10 and 25. Is there anything broken?
take it back for a warranty inspection / repair or refund
maybe it is not genuine brand but a knock off in which case the manufacturer would like to be told about
Jun 15, 2017 | Tissot Watches
I just got the watch as a gift on x-mas it stopped working yesretday while I was wearing it mens giovanni self winding I pushed the second hand button A and nothing I didn't drop it or get it wet or...
Having read the limited instructions for this watch, it does not seem as though there are many options available!
If you haven't already done so, try pressing A again.
If nothing happens, press B
It could be that the watch has simply stopped because it needs re-winding (it depends on how long it had been running when you got it.
To wind the watch swing it gently from side to side for a few minutes. ( some makers say swing it 200-300 times!).
If you still have no joy, then contact the makers help line; go to http://www.raymond-weil.com/EN/Swiss-Watch-Company/After-Sale-Service.html to find your nearest service center.
Jan 03, 2011 | Raymond Weil Don Giovanni Chronograph...
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Mintues hand problem.
    There are two reasons for this. First- you distorted minute hands hole and now it is not sitting tightly on pinion. Second- when you pulled off the minutes hand, you lifted cannon pinion. As the result it is loose and swings freely. I do understand you have no knowledge how the watches are build, so, visit your nearest watch repair shop and ask to fix it. Please, do not take it personally - it is just because you can't do that without watchmakers knowledge, so, save your nerves, time and watch. Rate me, plz.
    Mar 18, 2010 | Timex 27191 Wristwatch
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    Tissot 1853 stops running all the time have had it in for repairs and they state that it must be my husband de- charging the battery? I believe it is a crappy watch that we payed too much for? Can we do...
    Ive never heard of anyone de-charging a battery! Sounds like those people didnt really know what they are talking about! Its very possible that its running without the hands moving! Its a very common issue in our shop. Watch has what we call a beat which comes from a magnetic rotor. We put some watch oil on the pivots where the wheels are and then place it on a machine that has a magnetic field and forces the hands to move and that can dislodge any old thickened watch oil or anything else that could build up...the watch may have even gotten wet at one point and could have rust or even corrosion inside the movement!
    Find a good reputable watch repair shop and see if they can re-evaluate the watch and come up with a better reason that he is "de-charging" a battery! :-)
    Jan 19, 2010 | Watches
    I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
    DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
    Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
    I have not worn my SEIKO kinetic wrist watch for a
    Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
    Jun 05, 2009 | Seiko Kinetic watch
    Pulsar Mens Wrist Watch
    I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
    Jan 30, 2007 | Pulsar PXF216 Wrist Watch
    Neff Daily Watch Logo
    Top Neff Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Neff Watch Expert? Answer questions, earn points and help others
