Question about Toshiba E-Studio 356 Multifunction Copier
Toshiba e-356 error C440
Error code C440 -how to solve problem
    New Friend:
  • 25 Answers
Try to have a look on that.
And sign the correct (if there) answer
http://www.fixya.com/support/t24964554-toshiba_e_studio_356_copier_error_c440
Posted on Aug 17, 2015
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Posted on Apr 11, 2010
mce_sys
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
djuksoni
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
  • 29 Answers
SOURCE: cada ves que predo mi
tienes un problema en el area del fusor, lo puedes resetear siguiendo estos pasos:
1.- prende la maquina presionando 0 y 8. espera unos 5 segundos hasta que la copiadora haga un sonido y prenda en test mode
2.- escribe la numeracion 400 y presiona start.
3.- te debe de aparecer un numero de error, para resetearlo solo escribe 0 y dale set o start.
4.- apaga y prende el equipo normalmente y has pruebas funcionales.
si tu equipo sigue marcandote problemas vas a necesitar reemplazo ya sea de las resistencias termicas y el sensor de temperatura, algun fusible o alguna tarjeta controladora de alto voltaje.
Suerte...
Posted on Mar 23, 2011
C440 toshiba 306 se
Change the current status counter value (08-2002) "4" to "0" for
Jun 16, 2016 | Toshiba Office Equipment & Supplies
Model 233. What does error code C440 indicate?
C440 error indicates a fuser temp too high or too low. SOMETIMES it's random and can be reset by 1. hold down the 0 and 8 keys while turning on power. 2. Enter 400 press Start. 3. Enter 0 press Set or enter. Copier will begin warm up mode. If the code recurs, you will need the fuser unit rebuilt or replaced.
Oct 04, 2015 | Toshiba Office Equipment & Supplies
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
C440 error
chik tha power suppl bord
Nov 15, 2013 | Toshiba E-Studio 456 Copier
E studio 456 c440 error code solution
Hi
C440 error on device problem toshiba e-studio 456 se
Please let me correct code.
400-08 code did not work on 456
Thanks
May 22, 2013 | Office Equipment & Supplies
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
oolmii@yahoo.com
Aug 12, 2012 | Toshiba Estudio 200L Copier
What is error code C440 on an Oce IM2330?
The fixing unithas an overheat error, It needs parts replaced
Feb 07, 2012 | OCE Office Equipment & Supplies
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 356 Multifunction Copier Logo
961 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
