Question about Mitsubishi HDD Navigation CU-H9700
Mitsubishi hdd navigation system CU-H9700
It wont play CD or DVD disc & i think the system is somehow lock. do i need the remote to work it or somehow to unlock it. please help me :(
techman
  • 3130 Answers
SOURCE: unlock code
Bypassing the V-Chip Lock on most Mitsubishi sets: Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
Posted on Mar 29, 2007
SOURCE: Problem with Mitsubishi HD 1080
Yes. When you moved it you likely broke a cold solder joint on one of the circuit boards. Since Mits RPTVs are renown for their bad convergence ICs that is where I would start.
The ICs get hot and the solder joints give way sometimes causing the ICs to fail. Mitsubishi's are famous for this problem.
If you are going to do it yourself, you will need a service manual.
If you are going to call in a repair tech, have him check the convergence board first and then the main power supply board.
Sorry it is not good news.
Posted on Sep 25, 2008
lancer721
  • 229 Answers
SOURCE: 2003 Mitsubishi Eclipse
Make sure there isn't a secondary fuse box like under the hood or under the dash to start. Many vehicles now have two fuseboxes with redundant fuses for the same system. If thats not it you need to get a cheap voltage meter and start diagnosing from the farthest point out til you find the place where you voltage isn't getting through. Good Luck
Posted on Nov 07, 2008
SOURCE: problem
There is possibly a short under your middle console that is blowing the fuses....I had the same problem with mine and had to take my whole console out to fix it!
Posted on Dec 09, 2008
Suzman
  • 642 Answers
SOURCE: My Mitsubishi colt CZ1 (07
Central locking works by way of little electric motors that engages and disengages the door lock. The drivers door has an additional set of contacts in the actuator which signal the controller when it changes position. The controller activates the servo motors when a signal is received from the receiver or from the drivers door servo motor. So in your case I suspect the motor part of the drivers door actuator is done for.
To replace you will have to remove the inner driver's door panel to get at the actuator. The actuator itself cannot be repaired and needs to be replaced as a unit.
Posted on Apr 29, 2011
Testimonial: "Very helpful answer and a prompt response. Thanks"
Clarion VCZ625 6-Disc CD/Video CD/DVD Changer
I would say to take it back regardless of what the problem is. I would say the unit is bad. Does the remote work the other functions? if it does not then the remote could be bad, if the remote does work the other functions, I would think the unit is bad.
Jun 23, 2007 | Clarion VCZ625 6-Disc CD/Video CD/DVD...
When finish rec from HD to DVD it wont finalize it , Keep coming up Navigational Error , even when playing normal DVD
you can not record from HD to DVD because it has a lot of difference in resolution .....for HD you need blueray disc not dvd.....
Sep 28, 2015 | LG Rht599h 500Gb Hdd Dvd Recorder With...
Mitsubishi NR-VZ800MCD Car Navigation system not working
I have exactly the same problem. The system needs to be re booted with the disc that you must have got when you bought it. It always happens when the battery is disconnected. I lost the disc and so now am looking for a copy.
Jun 17, 2013 | Computers & Internet
Maserati navigation cd
Just Purchased a 2004 Maserati CambioCorsa Coupe with a Blaupunkt remote 5 disc CD Player in the trunk. The indash info center recognizes its existence but will not communicate. The Blaupunkt will accept a CD but will not play it or release it. I cannot see any model numbers Etc, any ideas anyone.
Mar 05, 2010 | 2005 Maserati Quattroporte
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Mitsubishi HDD Navigation CU-H9700 Logo
Top Mitsubishi GPS Experts
Andrew D
ray gallant
Are you a Mitsubishi GPS Expert? Answer questions, earn points and help others
