Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Whirlpool Gold icemaker won't make ice
The icemaker no longer will make ice. It won't even fill the tray with water.
  • Whirlpool Master
  • 4,654 Answers
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Whirlpool Gold icemaker won't make ice - 338173cd-521f-46d1-87dc-4153dfabfcee.jpg
Posted on Feb 16, 2014
  • 35 Answers
SOURCE: Water not filling up the icemaker
it sounds as tho you do have solenoid prob.but it could also be an ice over sit at your water inlet tube that is situated near icemaker.
Posted on Jun 25, 2007
SOURCE: icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Posted on Apr 27, 2008
  • 1073 Answers
SOURCE: Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
Posted on May 11, 2008
ghappliances
  • 126 Answers
SOURCE: Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
plnolte
  • 62 Answers
SOURCE: Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
Posted on May 12, 2009
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
The icemaker whirlpool gold model GRZSHWPBOZ
either the water valve is bad if so replace it or the tube that delivers the water to the tray is frozen . ck both and replace the one that is bad . hopt this helps mm ..
Apr 06, 2010 | Refrigerators
Whirlpool gold ice maker not filling with water to make ice
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Icemaker not making ice
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Refrigerators Logo
245 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
