Question about Dryers
Kenmore 97575100 It won't stop--ever. Have to pull the plug. Runs with door open and after the timer completes the cycle. What part needs to be replaced?
    Scholar:
  • 101 Answers
Most likely you have a control board problem. All those issuse point to the only thing that effects all those parts/functions of the dryer. This is about a $100 part. Call Sears parts and get a quote or go to http://www.searspartsdirect.com. Labor to replace will be in the $80-120 price range unless you bring it to a repair shop which could be cheaper.
Posted on Feb 16, 2014
4 Suggested Answers
  • 94 Answers
SOURCE: Kenmore Dryer Model 11063102101
Probably the timer is defective and needs replacing.
Posted on Oct 07, 2007
SOURCE: Kenmore Model 96573220 won't stop at end of cycle.
I figured out it was the start switch and took the switch apart and repaired the welded together contacts. Took only a few minutes.
Posted on Dec 28, 2009
SOURCE: Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Posted on Jun 02, 2013
H3 6102 will not stop running.
Dear Sir:
See this possibles causes:
1) Defective Timer. Test it, or replace
2) Motor fault, need repair or replace
see the diagram
God bless you
May 23, 2012 | Kenmore Dryers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
Water runs out of the rubber gasket inside the door
replace water inlet vale it has gotten debris in it and not allowing it to close
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
