Question about Craftsman Garden
How do i remove the battery shroud on my craftman 48v rechargeable mower model#2473704802
3 Suggested Answers
SOURCE: battery charger for craftman electric lawn mower
junked the charger connectors and replaced the connectors with better type of connectors that an old man can get a hold of to take apart to connect the charger when needed very poor design for elderly use.
Posted on Jun 15, 2009
  • 93 Answers
SOURCE: craftman 6.6 self propelled mower blowing oil between the upper &
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Posted on Sep 14, 2009
Battery will not recharge
First clean battery posts and cables. Next check if plug is plugged in, one coming under shroud. You can check voltage there.
May 25, 2015 | Garden
How do I remove the Battery Shroud for 247.370480 19-inch Rechargeable Rotary Mower?
First there is 4 batteries connect in series under the cover.
You will need a flat head screwdriver and some wood wedges. The motor shroud has four slots on the cover, two on each side. 1.) Place the flat head screwdriver into one of the four slots in the cover. 2.) Push in the tab behind the slot with the screwdriver while lifing on the cover at the same time to release the tab. 3.) Place a small wooden wedge under the cover so that it doesn't lock back into place. 4.) Do this on all four slots to fully release it. It might be best to go Front Right, Front Left, Rear Left, and then Rear Right. Good luck!
Nov 02, 2014 | Garden
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will a shaft from a 14 yr old craftman lawn mower fit on a 2 year old craftman
need to have model numbers from both engines with spec numbers as well but most likely no
Jun 21, 2012 | Garden
How to replace starter
!- remove the battery ground cable
2- remove the battery cable to the starter
3 remove the shroud on top of the mower engine
4 -remove the two starter bolts
5 remove starter and reverse procedure.
Nov 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery charger for craftman electric lawn mower model no 625 connector from charger to battery is broken and need new connector or complete charger
Jun 13, 2009 | Craftsman Garden
Garden Logo
24 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
