Question about Car Audio & Video
Almani s3-12 sealed box specs - Car Audio & Video
Almani protection light coming on
fix your ground make sure its thick as the power and its touching bare metal
Mar 13, 2013 | Almani Car Audio & Video
What size sealed enclosure does this requrie
To get the proper box for that speaker.You will need the speaker specs from the manufacturer or try to research it online with the model number.Once you get the specs .You can go to http://www.diyaudioandvideo.com/Calculator/Box/ .Enter the required specs onto online calculator and it will calculate box dimensions for you.Good luck
Jan 30, 2011 | Planet Audio BB212D Car Speaker
I want to build a box for my kappa subs and i need to know what specs would make them sound great. they are goin in my 97 chevy ext cab truck. the box is going to be my back seat also
http://manuals.harman.com/INF/CAR/Boxes%20and%20Parameters/1001dvc.pdf
Not knowing your musical preference, take a look at this spec sheet and pick the sound you'd most like. The bandpass design usually gives the most SPL, but a larger box is probably deeper while still having good volume. Some audio purists say a sealed box sounds the best, subjectively, but the SPL isn't as great.
Nov 08, 2010 | Infinity KAPPA 100.1DVC Car Speaker
What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
Spec for type r 10
  • 10" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 26-600 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 83 dB
  • top-mount depth: 6-7/8"
  • sealed box volume: 0.5-0.8
  • ported box volume: 0.6-1.3
Nov 20, 2009 | Alpine Car Audio & Video
My 15 & 10
On a 10 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 20 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. Or 275mm high, x 275mm wide, x 275mm deep. Seal the boxes with silicone for better bass
Oct 21, 2009 | Hollywood Sound Lab Hollywood Digital...
In need specs to build a box
Hello fmaisonet77,
Here's a link to Clif Designs website the specs on your sub.
They recommned a 1.75 CuFt sealed, or a 2.75 CuFt ported enclosure.
Hope this helps.
Oct 07, 2009 | Clif Designs CD1200C Car Speaker
I need to build a box for 2 AudioBahn AW1505Q subs need the specs on how big the box needs to be
try a electronics store like jaycar? they have the specs for sealed and ported speaker boxes depending on size and watts
Jul 28, 2009 | Car Audio & Video
MTX 5500 SLEDGEHAMMER 12" ENCLOSURE
According to MTX they need 1.25 cubic ft per sub sealed and 2 cubic feet vented. Most pre-fab boxes will work for those subs.
Jan 06, 2009 | MTX Dual 12" Subwoofer Enclosure (Bs212s)
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
