Question about Exercise & Fitness
Error code 1 on triumph treadmill 400t - Exercise & Fitness
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
ercupa190
  • 12223 Answers
SOURCE: triumph treadmill 400t does not start
see the video and fix it.
God bless you
Posted on May 23, 2013
Triumph 400T belt won't turn, and get E1 error message
You have to check the Speed sensor of the tread. IF the speed senor is faulty this problem can occur. Normally in all treadmills E1 denotes the speed sensor error.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Triumph Academy Sports 400T Treadmill
The wire on the back of the tridmil triumph 400t came off and it want light up and you can here that it's on but it is not running.
Triumph™ 400T Treadmill ' Academy
www.academy.com > ... > Cardio Equipment & Machines > Treadmills
Rating: 3.4 - ‎67 reviews - ‎$259.99 - ‎Out of stock
The Triumph™ 400T Treadmill features a 1.50 CHP motor and the AEROsoft™ cushioning system.Missing: motorcycles
Triumph 400T Treadmill - YouTube
? 0:31
https://www.youtube.com/watch?v=TZdf5fIAVMU
Jan 4, 2012 - Uploaded by Academy Sports + Outdoors
Visit Academy Sports + Outdoors or academy.com to view theTriumph 400T Treadmill which is featured at a ...Missing: wire ‎back
Triumph - 400T - TM397B - 2011 - FitnessRepairParts.com
Dec 26, 2015 | Triumph Motorcycles
My treadmill runs for 9 seconds and stops and shows E1
Might be the power supply. That's about all I can think of. It runs but gets hot very fast and shuts down
Nov 24, 2014 | Triumph Academy Sports 400T Treadmill
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
Treadmill squeeks
Lube the treadmill belt with treadmill lube
Mar 12, 2014 | Triumph 400T Treadmill
Looking for manual for triumph 400T treadmill
call service dept 1-866-864-3840 or downLoad it online
Jan 29, 2014 | Triumph Academy Sports 400T Treadmill
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
