Question about Refrigerators
Kenmore Elite Model 106.4442*600 control box off but lights work and both refrigerator and freezer are not working
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Posted on Nov 17, 2008
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: Bottom freezer works but top refrigerator doesn't. Kenmore Elite.
It appears your damper or damper solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Lights would not go off on my Kenmore Elite model #79577253601. light housing melted. Replaced housing and lights and again will not go off.
The door switch controls the light, and it should turn off power when the switch is depressed by the door. If it does not, it needs to be replaced.
Aug 31, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Just bought a kenmore elite bottom freezer trio model and display panel shows o ff. Expect this means whole unit is off but manual does not say how to turn ON in the setting the controls section of manual....
I just purchased a similar model and had the same frustration. Finally called the store and it was in DEMO mode. Open the freezer draw and hold down the Ultra Ice & Refrigerator Temp buttons simultaneously for 5 seconds. That worked for me and hope it will do the trick for you.
Jul 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Dec 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
