Question about MTN Gearsmith New 1500w Commercial Industrial 20l Autoclave High Pressure Steam Sterilizer Tattoo Dental
Lack of water
The lack of water light keeps coming on
  • Christopher Walters
    Christopher Walters Jun 02, 2017
    simple repair, drain all of the water out of the unit, then load it in your car and bring it to the local scrap metal yard, graciously accept the $25 they give you and never but a no name, off market, POS again. stick with Midmark, Tuttnauer or Steris.
    Habit-Forming:
  • 55 Answers
Change water level sensor.
Posted on Jan 04, 2015
  • 25 Answers
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Posted on Oct 29, 2014
I have a 2005 lincoln ls i drove through water up to door car died it wont start it keeps clicking but battery is not dead, aslo the alarm keeps coming on after i try to start it lihts flicker to?
My advice is not for Lincoln cars only but all cars equipped with electronic control units and sensors.
Entire vehicle needs to be checked for electrical system integrity due to possible water damage. Especially fuse box/boxes, damaged relays and fuses inside if there are any. Before its done, its better to not turn on the vehicle. You can separate positive terminal from the battery if its applicable. Alarm comes on possibly due to lack or mixed signal/voltage coming from system sensors to control unit.
Jul 27, 2016 | Lincoln Cars & Trucks
My brake lamp light keeps coming on as soon as i start my car and step on the brake the light comes and stays on i've checked all the rear lights and they all work
will be due to lack of pressure more than lack of fluid, try bleeding the brakes, the light should go away unless you have a split in one of your brake lines or your master cylinder is leaking
Feb 18, 2014 | Acura Cars & Trucks
Hi i have a two day old beko dcu 7230 tumble dryer the water tank and clean filter light keeps coming on even though they are clean and empty is my product faulty.
not too many dryers w water tank, but the air filter light maybe due to a lack of air movement. If you have replaced an old machine, then your problem may be with the existing exhaust and duct work, you'll need to clean them out thoroughly to know. You may have to go outside or up on the roof as sometimes these also have trap doors that become stuck.
Nov 09, 2013 | Dryers
Over heating and oil light keeps comming on
maybe you should climb under it and take a good look.... more things than a thermostat can cause overheating. water pumps bad impellers worn off, plugged radiator bad fan... even the lack of oil can cause overheating
Feb 26, 2018 | 1986 Suzuki Samurai
Aux light flashing and pump is pulsing
The Pump pulsing is sounding like maybe there is not enough water in the spa to keep enough water to the front of the pump.
This is called 'cavatate" and is caused by lack of water to the front of the pump.
Also check the gate valves in front of the pump and the other side of the discharge of the pump to make sure they are completely open.
The Light issue sounds like maybe a relay on the circuit board could be bad or the transformer for the light is going out.
RodUS Parts Center888-521-6813
Mar 01, 2013 | Qca Spas Pool & Spa
Pilot light keeps going out during hot days
Solution is probably better ventilation to gas water heater.
On hot days, heat and lack of ventilation can cause pilot outage.
Hot air causes oxygen molecules to move farther apart, and combustion is no longer supported so pilot goes out.
Open following links:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 04, 2011 | Rheem Water Heaters
Karcher K3.86 doesn't seem to be able to sustain pressure. Keeps trying to pressurize then stops. Only keeps pressure while I spray. SOmestimes it totally shuts down, I guess when it overheats.
probably water flow check filter going into pump there is anut coming out on an angle going into the pump wire gause filter inside if this is clean follow it back to water supply symptoms definately indicate lack of water youdoit
Jul 26, 2009 | Garden
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
MTN Gearsmith New 1500w Commercial Industrial 20l Autoclave High Pressure Steam Sterilizer Tattoo Dental Logo
2,200 people viewed this question
Top MTN Gearsmith Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a MTN Gearsmith Science and Laboratory Expert? Answer questions, earn points and help others
