Question about ASUS G Computers & Internet
Cannot open wim file - G ASUS Computers & Internet
I want to reboot my pc asus x5dc but it can t .but i have one message apeare when i want to continue the booting "cannot open WIM file" with a big word ERROR
What were you doing before this error? "Windows Imaging Format (WIM) is a file-based disk image format."
Try http://www.sevenforums.com/tutorials/15162-wim-file-extract-modify.html This tutorial is all about how to mount or modify install.wim or any .wim file.
May 31, 2011 | Computers & Internet
Boot manager compreessed
Sadly the startup repair option or any other repair option in windows 7 startup recovery failed to solve this problem. this can be solved by
reboot your pc
select the repair your computer option
command prompt
at the prompt type notepad (since the recovery option boots from a seperate wim image it has notepad built into it )
press ctrl + o which invokes the open file dialog
go to the open file field (ALT+N) and type c:\boot and also see for the c:\bootmgr
file. right click it and deselect the option of "compress files to save disk space"
when we apply the boot manager is again decompressed. also if someone finds this harder we can directly deselect the compression option by reversing the process used to compress the drive
thats it . we are done
Apr 16, 2011 | Computers & Internet
Restore factory Settings on a Dell Inspiron
hi..
if you have windows xp then you need to turn your computer as soon as you do that before you see the windows xp logo hold down the control key and keep tapping f11 key.it should take you to the screen fro factory settings and if it is windows vista then you can go ahead and press f8 and then choose repair my computer,hit enter which will then prompt you to login in once you log in it will tell you to choose the options from the options listed below choose the one which says restore factory default...you computer will be restored to factory settings..
vedhick
Feb 26, 2009 | Motorola Mobility OEM Bluetooth USB PC...
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
