Question about Dell Inspiron 1750 Laptop
Need more details on how to re connect the hard drive , but
But first on how to get to it from back to dis connect hard drive , and reconnect harddrive on Dell INSPIRON 1750 STEP BY STep would be nice thanks again , and hope this works . also will i loose info by doing this ?
    Top Expert:
  • Dell Master
  • 22,782 Answers
Try this;https://www.youtube.com/watch?v=yQeHCjN3ods
And yes, all the data on the old drive stays with the old drive. You will need a usb to sata connector and then copy your data across.
Posted on Feb 16, 2014
4 Suggested Answers
billspeer
  • 180 Answers
SOURCE: dell inspiron 1550
http://support.dell.com/support/edocs/systems/ins1501/en/index.htm
However, if it's really a 5150 (since the 1550 is a server) use this link:
http://support.dell.com/support/edocs/systems/ins5100/en/sm/display.htm#1084976
This will give you the exploded view.
Good luck. If you have already handled a thinkpad, I foresee no problem with this one. They're all pretty much the same.
Please rate this accordingly and thanks for using Fixya.com
Posted on Jan 10, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
  • 846 Answers
SOURCE: upgrade-replace Dell inspiron 6400 laptop's hard drive ???
Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Posted on Jul 26, 2010
Samsung external hard drive
!! You have failed to provide a detailed problem. !!
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Jan 29, 2013 | Samsung G2 Portable External HX-MU064DC/...
Hard drive
You can check this link for the step by step way to reconnect your hard drive: http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
Hope that helps.....
Jun 21, 2008 | Gateway 505GR PC Desktop
How to remove acer laptop bios password
You'll need to open the laptop and reset the CMOS battery.
I'd recommend doing a search for you make and model for additional details. But in brief:
1. Disconnect power adapter and remove the battery.
2. remove the screws around the hard drive compartment (bottom of laptop) and slide off the cover
3. remove the screws holding hard drive in place and slide out the hard drive
4. Disconnect or remove the small power lead that connects the battery to the mother board.
5. Reconnect and place everything back together.
Jan 11, 2013 | Acer Computers & Internet
Trying to install windows on a IBM Think Centre mt-m 8183-360 SN kcmc6k7 every time it goes to install it tells me no hard drive is attached
Either the hard disk is faulty or it needs reconnecting so it makes proper connection.
Remove the data connector from the hard drive and connect it back onto the hard drive. Also remove the other end of the data cable from the motherboard and reconnrct it again.
When you install Windows again and the hard drive is not detected then the hard drive is faulty and needs to be replaced.
Jun 23, 2011 | Computers & Internet
I had a problem with my pc it cant power on and only green light in the board i see. any advise please
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 21, 2011 | Computers & Internet
Took RAM out. Put RAM back in. Removed hard drive. Reconnected hard drive. Connected a second hard drive as a slave. When I plugged it back in I noticed a small red LED (PLED) beside the 5th card slot had...
Single long beep - the RAM is no longer recognized as present. Try the ram stick in another pc, if it works there then the motherboard has died, you will have to replace it.
Oct 20, 2010 | DFI CA64-EN Motherboard
My hard drive donesn't work
It may not have enough power.
Try supplying external power to the drive.
Dis-connect other usb devices.
Or plug-in via a usb hub that has it's own power.
May 31, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
My iomega external hard drive light doesn't come on and my pc doesn't recognize it. I bounced the usb cable by accident and it came loose while i was listening to music from it. When i reconnected the...
When you disconnected the hard drive by pulling the USB cable from the computer without using the remove hardware feature it will cause the computer to not recognize the drive. You should be able to power down the drive and then re-boot the computer. After the computer has restarted then reconnect and power up the drive and windows should detect it again. Some of you files on the drive might have been corrupted when this happened so I would go into my computer and run check disk to repair any errors on the drive. If you reboot the computer and the drive still does not respond then you may have caused damage to the drive. You could then try dis-assembling the case for the hard drive and installing it into the computer and see if it works. If it works in the computer then the external hard drive's power supply is defective if it does not the the drive is damaged.
Nov 19, 2009 | Western Digital 500GB My Book Pro-External...
A diagram to assemble and dis- assemble to replace a new hard drive
http://repair4laptop.org/contrib/gateway_solo_9550/gateway_solo_9550_notebook_disassembly.pdf Will give you the diagram....but it shouldn't be needed. Bottom of laptop, with hinges facing away from you. Lower Right corner there is a 3 and a half inch panel. 2 screws removed, lift panel. There's your hard drive. If it's got screws holding it down...it should...then remove those screws, and gently slide it right until its out of the mount. reverse steps to install new one.
Apr 30, 2009 | Computers & Internet
Dell Inspiron 1750 Laptop Logo
mukhtar21 shaikh
mukhtar21 shaikh
