My RC71 remote stopped working. I have changed the batteries but it seems totally dead...can anyone help or give me some suggestions
  • 67 Answers
SOURCE: 2003 Impala - mystery problem???
you have something thats staying on with power when you shut the car off,first check all lights glove apartment,underhood,in trunk ,just because ther closed doesnt mean the light is off,check your car at night it might help to see the lights,if not another way is to take a multi meter to the battery and while some holds the meter pull out fuses in your fus box one at a time to see when the meter makes a change,this will help you to narrow down whats staying on and draining the power from the battery,if this helps please give me a fix ya vote
Posted on Jul 14, 2008
SOURCE: battery totally discharged cannot get into boot to change battery
Open passenger door manually with key, then pop bonnet and remove plastic cover on passenger side at bulkhead. You will then see a connector from battery which can be mated to a slave battery in order to work remote to open boot.
Posted on Dec 15, 2008
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
SOURCE: JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Posted on Mar 11, 2009
james3751
  • 614 Answers
SOURCE: Kenmore a/c remote control doesn't work
Google AirConditioning remote controls. Go to parts warehouse and check there. I have purchsed two remotes for different AC units on line for about 50 dollars.
Posted on Jun 12, 2009
Why does my battery keep going dead?
It would be useful at some stage to measure voltage across the battery at rest and also with the engine running slightly above idle.
You should see something like 12V at rest, and 13V+ when running. You need to eliminate the basic battery/charging cct from consideration. Other weird symptoms lead me to think there could be an earthing problem but better to rule out the first things first.
Sep 15, 2014 | 2005 Ford Taurus SE
clean the circuit board on the remote moisture might be the problem
Aug 14, 2008 | Philips DVD750VR DVD Player/VCR
Sansui tv remote codes
1869,1888,1864,1860. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Nov 30, 2013 | Televison & Video
Directv rc71 remote control
how do you program a rc71 to a tv. Not to a rvu but to a tv so the volume works and can power on and off tv please help.
Apr 22, 2013 | Televison & Video
Remote stopped working so we bought a new battery and it turned on for awhile, now it's totally dead. Could the contacts on the base be worn out so it doesn't charge?
This seems to be a common problem with the 890. In fact, Logitech have an entire page dedicated to charging problems with the 890:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9169/kw/charging
This page contains a troubleshooting guide and if you are still unable to solve the problem, it lists the information you need for contacting Logitech support. Sorry, but there is too much information to paste it all here.
Hope this helps.
Regards,
BElectric
Nov 19, 2010 | Logitech Harmony 890 LCD Remote Control
Remote to my 99 vw jetta seems to be dead and car wont start...
This is a feature that is fitted to stop your car being hot wired and stolen. It would take a huge amount of work and money to bypass. The key fob contains an electronic immobiliser. Take the key to a VW dealership or a Car key specialist and get the battery you need. Some remotes take standard 'button' batteries so potentially could only cost you pocket change.
Dec 19, 2017 | Vehicle Parts & Accessories
Battery totally discharged cannot get into boot to change battery
Dec 14, 2008 | 1996 Mercedes-Benz C-Class
Suddenly my remote control device to lock and open doors in passat 2001 stopped working, the red light is blinking, but nothing happens, can anybody help?
replace the battery in the remote .it will stop working even before the batt is completely dead.
has anyone worked on the car lately?
Jun 30, 2008 | 2001 Volkswagen Passat
Remote doesn't work
the IR [infrared] on your DVD is not working have tech check your DVD for defect.GOOD LUCK
Apr 23, 2007 | Samsung HT-DB120 System
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
