Question about LG NB3530A
Pairing code for LG NB3530A
I'm looking for a way to unlock the pairing code for my LG NB3530A Sound bar. I want to control the sound with my Xfinity XR2 P2 remote. Thanks!
  • 899 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
Phone Squad
  • 31 Answers
SOURCE: Bluetooth pairing code
The default pairing code for most bluetooth devices is 0000.
Try this to see if it works.
Thanks for using Fixya
Posted on Dec 14, 2008
  • 905 Answers
SOURCE: i need the pairing code for LG KS360
The default pin code for most devices, especially headsets, is 0000 unless it was changed.
You should be able to go into the bluetooth settings on each phone, and find the security code there, or at least change it.
Posted on Sep 15, 2009
SOURCE: Cant get LG HBS-250 into pairing mode
Make sure the headset is off when you hold the call button for 5 sec. And don't stop holding it when you hear/see something happen after the first 2 sec. Keep holding it for the full 5 sec. The blue light will become solid which means it's in pairing mode.
Posted on Dec 07, 2009
SOURCE: i lost connection with my LG HBM-310 Bluetooth and
When your phone ask for the pass key type 0000
Posted on Feb 03, 2010
What is the code for xfinity cable xr2 remote control?
Your XFINITY remote can be paired with XFINITY X1 TV boxes, allowing you to control the TV box even when it is placed out of sight, such as in an entertainment center or in another room (up to 50 feet away). XFINITY remotes can be identified by the model number on the back panel or within the battery compartment of the remote.
Note: Once your remote is successfully paired with a TV box, it will not control any other TV box until paired with the other TV box. XFINITY remotes can only be paired with one TV box at a time.
To Pair an XFINITY Remote Note: These instructions apply to XR2, XR5 and XR11 model remotes only.Make sure the remote batteries are installed and your TV and TV box are powered on.Set the TV input to the input connected to the TV box.Press the Setup button on your remote until the LED at the top changes from red to green.Press the xfinity button on the remote. The LED will begin flashing green. (Note: When pairing an XR2 or XR5 remote to a DTA, you may need to press the xfinity button up to five times).Follow the instructions by entering the three-digit, on-screen pairing code.
Once the on-screen pairing code is correctly entered, your remote is paired with the TV box. Note: If you do not see on-screen pairing instructions after pressing the xfinity button in step four, press the xfinity button again. You may need to press the xfinity button multiple times if there is more than one TV box in range.
how4474_072816_01-kmuj4sm5av3gyijxunj5wf5e-1-0.png NOTE THE BELOW CODES ARE FOR THE SAMSUNG SMART TV's ONLY
Type in the 4-digit or 5-digit code listed below using the number buttons. Additional codes may be found in the remote manual.
Most likely code
10812
Others to try
11632, 10702, 10060, 11959, 10766, 11903, 11060, 10587, 10329, 10482, 10650, 10814, 10032, 10178, 10030, 10019, 11575, 11597, 10427, 10408, 10217, 10056, 11581 for more info on what device you are trying to pair it with the codes are available here > https://www.xfinity.com/support/remotes/ Just select the Remote and the device and continue and the page will display the most common codes for that Device you are trying to pair it with.
Apr 26, 2017 | Televison & Video
When pairing my samsung cell phone or tablet with a LG sound bar I can play my music but after a few minutes of working fine I lose the signal and have to pair again...what could be causing this?
Check your settings on your phone. Make sure you are not pairing with something else at the same time. Also check if something else is trying to pair with the sound bar while you are using it.
Dec 14, 2016 | Samsung Cell Phones
How do I pair with my Motorola e?
Just reboot your Motorola device. And try again. I'm assuming that you re having trouble pairing the devices. If the problem is that this is your first time pairing, then just head over to this link and download the manual.
http://www.lg.com/au/support-product/lg-NB2540
Sep 22, 2015 | LG NB2540 -Sound bar
What are the TV codes for pairing xFinity remote
0278,0277,0274.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 03, 2014 | LG Televison & Video
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
I cannot pair my LG phone to my Blueant X3 micro bluetooth headset. The phone recognizes it, but doesn't let me pair. During the attempt, I receive "device pairing incomplete" then I am asked to enter a...
You have to turn off the Dare's autopairing feature. The Dare was designed to autopair with devices using the 0000 code. The Blueant X3 uses the code 1234 so the autopair won't work.
Once you turn the feature off, start the pairing process all over again and it will work.
Unfortunately you'll have to turn the X3 on through the Dare's bluetooth menu every time you want to use it. You can't use the "on" button on the X3.
Sep 26, 2009 | LG Dare VX9700 Cell Phone
LG NB3530A Logo
105 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
