Question about Whirlpool Compact Stackable RV Washer and Dryer
I have a whirlpool "Thin Twin" stackable washer and dryer. The spin cycle wont work and the water wont drain. Call yu tell me what the problem is please.
  • 87 Answers
SOURCE: Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
Posted on Jun 08, 2007
SOURCE: LTE6234 Whirlpool Twin Thin Timer Broken?
The problem I have with my Whirlpool ThinTwin is that when I pull the washer knob the water does not start filling even though there is water in the apartment unit. The dryer works so i know there is power and not a circuit breaker issue as I have checked that as well.
When I turn the knob and pull in any position nothing happens. Any suggestion would be greatly appreciated.
Posted on Feb 03, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
  • 1122 Answers
SOURCE: Whirlpool Thin Twin YLTE6234DQ2
YOU CAN DO THIS.,POP THE FRONT PANEL OFF,GO TO THE SWITCH PLUG JACK ON RIGHT SIDE UNPLUG JACK,ON THE SWITCH SIDE WIRES CUT THE OUTSIDE WIRES PUT THEM TOGETHER WITH WIRE NUT,LEAVE GREEN WIRE ANONE,PLUG BACK INTO JACK,YOUR DONE,REMEMBER NOW IN THE SPIN CYCLE IT WILL WORK BUT WHEN YOU OPEN THE LIP IT WILL NOT TURN OFF SO KEEP YOUR HANDS OUT OF THERE,THANKS-MIKE
Posted on May 28, 2008
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Compact Stackable RV Washer and Dryer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
