Question about Sanyo Televison & Video
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
I put a DVD into the Sanyo DVD player. It sounds like it is spinning but after a while a message appears on screen advising "no disc." It doesn't happen with every DVD.
    Genius:
  • Sanyo Master
  • 1,552 Answers
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Posted on Feb 14, 2015
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
  • 6 Answers
SOURCE: Nexxtech N700-PD DVD Player - Discs will not load
Tracking motor has to be replaced
Posted on Jan 04, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
Dvd says no disc or disc error
It sounds like you need to clean u'r lens in the DVD player. You can buy discs that will do that for you. Hope this helps
Mar 14, 2012 | Sanyo DVW-6000 DVD Player/VCR
Says "No Disc"
If you have put a dvd disk in your dvd player, and it says "no disc" then try cleaning it with a dvd cleaning disk. It could be that the eye of your dvd player is dirty. You can get a dvd cleaner at any department store.
If you have put a dvd disk in your dvd player and its a home made or "burnt" disk and your player says "no disc", it usually means that the disk is the wrong format to be played on your dvd player. Try another disk.
If you have not put any disk in your dvd player, and it says "no disc" its just telling you that there is no dvd inserted for it to play.
Jul 13, 2011 | Sanyo DWM400 DVD Player
My VCR plays great but the DVD won't load the disk. I have changed disk types and manufacturers. Nothing has helped. Do I have to connect the AVI cables for the DVD to work?
the reason is because your dvd player inside got caught on something in side and now won't work for your disc it might even be off track...
Sep 09, 2010 | Sanyo DVW-5000 DVD Player/VCR
Disc shows loading then error on all dvd disc
Put a cd in the dvd player if it is marked that it plays cds... if it plays the cd your dvd laser is shot... cheaper to get a new unit. if it doesn't play a cd try cleaning the laser. and last but not the last thing try unplugging it for a short time then plug it back in... if nothing works get the one tool that fixs most everything...... take it to office depot and they can recycle the stuff inside and help keep the earth green...then onto wally world.
Nov 26, 2009 | Philips DVP5140 DVD Player
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Dvd keeps saying loading but won't play
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
Mar 14, 2009 | Samsung DVD-V3500 DVD Player/VCR
Does not play DVD
You need to open top cover and look inside dvd player cd tray. Does dvd / cd disc spins or having loading problem because grrrrr seems mechanical problem.
Let me know your finding to guide you further.
Thank you.
Oct 25, 2008 | Sony DVP-NS575P DVD Player
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
Televison & Video Logo
89 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
