Question about MEDIATECH Eiki LC-XG400 5000 Ansi Lumens Power Zoom & Focus Projector
How to reset LC-XG6400
All indicators flashing
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sharp AQUOS LC-42D85U tvgos does not work and hasn't worked for several months. What is the problem?
What is ur tv problem?No tv power LED light incation all or power LED light indication an OPC LED lights indication flashing togethers?Tries tv unplug,replug it back like about an hour later,for the tv to do a whole resetting.Tv might work again.Tv still have no pwer all?Yes.The tv power supply board it is dead,that the board where the power a/c cord plug into it.If the tv have both power LED and OPC LEDS lights blinks together.The tv main board Tuner signal board it is the cause and the problems it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board or a main Tuner signal board for the replacement.
Jul 03, 2011 | Sharp AQUOS LC-42D85U 42 in. LCD TV
Low ink light flashing even with new cartrige in it
The same thing happened on my MP270 printer and I had to reset the cartridge status by pressing and holding "STOP" button (circle with triangle inside) for 5 seconds, until the flashing indicator light stopped blinking.
For further details read the manuals here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=71896
Mar 05, 2011 | HP DeskJet 5550 InkJet Printer
Orange indicator light is flashing, won't go past starting up screen
Go to this link and download user guide and setup guide and reset your printer.
To reset your printer unplug the printer from computer and press Power button for 30-45 seconds and then restart your printer after 1-2 minutes for more details go through the manual:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=426109&
Oct 11, 2010 | HP Photosmart 8750 InkJet Printer
All lights are steady on and the printer won't do anything
Step One: Document for troubleshooting steps. Please refer the below mentioned web link for the troubleshooting steps. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01578337 Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address. Step Two: Download and install a patch for Print cartridge utility. 1. Go to the link mentioned below. 2. Click on the button ?Download only.? 3. Save the file on your desktop. 4. Double click on the file and follow the on screen instruction to install and fix the error. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-16009-3&lc=en&dlc=en&cc=us&product=374568&os=228&lang=en Note: Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address. Step Three: Semifull Reset. A semi-full reset will do the following: The user settings to the factory defaults, Language and country settings on some models Reset the All-in-One to the factory default settings by using these instructions: 1. Disconnect and then reconnect the power cord. 2. When the lights begin to flash, press and hold ON/Resume and Number of Copies. When only the ON/Resume light is flashing, release the buttons. When the ON/Resume light is steady, the reset is complete.
Jul 18, 2010 | HP PSC 1315 All-In-One InkJet Printer
Is a flashing power light on a sharp model # LC-19SB24U tv a repairable problem? tv will not power up.
push vol-, input, and power, at same time. keep push until tv start. Then you will see k123 at your screen. Now push vol-, and chan- at same time. You will enter service mode. Look for "error no reset" change the value to 0.
Nov 17, 2009 | Sharp Televison & Video
Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Sep 05, 2009 | Televison & Video
Sharp Acquos power indicator flashing and won't turn back on
Power indicator blinking is an indication that the protection circuit inside the unit has been activated to prevent further damage. You may need to have the unit checked by qualified technician. Most probable cause is a damage component in the power supply circuit or those directly connected to it (mostly output component).
Jan 05, 2009 | Sharp LC-65D93U Television
MEDIATECH Eiki LC-XG400 5000 Ansi Lumens Power Zoom & Focus Projector Logo
19 people viewed this question
Top MEDIATECH Office Equipment & Supplies Experts
jasbo
jasbo
Are you a MEDIATECH Office Equipment and Supply Expert? Answer questions, earn points and help others
